rims (offset)
Old Apr 15, 2003
7thgencivic9's Avatar
7thgencivic9 is an unknown quantity at this point
rims (offset)
I want 18" rims but not sure about the offset...anyone have a recommendation for offset?
Old Apr 15, 2003
666's Avatar
666
666 is an unknown quantity at this point
If you are going for a 7" width, most likely you are, then a +40 to a +44 should work fine. Most wheels are +42 which are perfect.
Old Apr 15, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Mine are 37, but I wouldn't recommend it if you want to drop the car very far. Stick to the 40-45 range, but 40-42 would be best.
Old Apr 15, 2003
yeah the tire size i think i want is 235/35/18
Old Apr 15, 2003
Jap-Euro Fusion
Woah... 235 is a bit wide. I'd stick to 215/35. 235 is gonna give you problems. If you're looking for tires that wide, you'll have to push the offset out into the high 20's-low 30's range and go to an 8" wide rim, and that will stick out a lot.
Old Apr 15, 2003
yeah lol that's what i meant my bad...yeah 215/35/18 hehe...so any recommended offset for that? lol
Old Apr 17, 2003
VNlilMAN's Avatar
The Standard One
ya anywhere from +40-+45 is fine. i run +42 18x7" 215-40-18 on neuspeed sports, not problems at all.
i wish i would have gone with 225-35-18 tho. 215-35-18 is a lil too thin, 215-40-18 a lil too thick, 225-35-18 sounds perfect.
Old Apr 18, 2003
2k2EXCOUPE's Avatar
TUCKIN 19s
I just ordered my rims, I was never asked about what offset I wanted? Is that bad? I just order 215/45/17 and he knew they were for a 2002 EX Coupe...
Old Apr 18, 2003
VNlilMAN's Avatar
The Standard One
chances are your getting the right ones then. most racing wheels that are 4x100 are within the +40 - +45 range
Old Apr 18, 2003
2k2EXCOUPE's Avatar
TUCKIN 19s
I hope...
Old Apr 18, 2003
tamazoid's Avatar
tamazoid is an unknown quantity at this point
well is 225-40-18 too wide and thick?
Old Apr 28, 2003
hey what if i decide to get 17s? What tire size and offset would be best?
Old Apr 29, 2003
VNlilMAN's Avatar
The Standard One
225-40-18 is too thick.. thickest i would go is 215-45-18
225-40-18 works with stock suspension, might rub a little tho. definitely NO for lowered cars...
17s i think 205-45-17 is perfect.. 205-40-17 is just way too thin and 215-45-17 too thick
Old Apr 30, 2003
cool thanx..205-45-17..sounds good
Old Apr 30, 2003
sawgunner06's Avatar
sawgunner06 is an unknown quantity at this point
I want to get 18"s
but am also going to get some coil overs
so what would be better
215/45/18
215/35/18
205/40/18
For everyday driving
Old Apr 30, 2003
VNlilMAN's Avatar
The Standard One
i dont think they make 205-40-18. 215-45-18 is kinda thick..
i would say 215-40-18. thats what i have. kinda thick but 215-35-18 is a lil too thin for daily drivers...
i would recommend 225-35-18 but i dont want you to blame me if it rubs. thats what i personally would go with if i replace my tires tho..
Old Apr 30, 2003
Bogus1's Avatar
Bogus1 is an unknown quantity at this point
Whoa
Those are way to big IMO. I would not put anything over 215-*-17 on my car. Remember the bigger the rim with the more torque is required to spin the wheel. Honda's don't have alot of torque. IMO those wheels will slow you down alot and cause bad gas mileage. With 35 profile tire you will be almost riding on the rim, you'll need to be careful around potholes and railroad crossings.
Old Apr 30, 2003
How low is your car and do they rub at all at that size.
215/40/18
Ok I am new.
Let me get this straight
215=What
40= The thickness right?
18= Rim Size?
So what is the 215
Old Apr 30, 2003
Ok I just read what Bogus1 had just wrote.
So 18's are a little big for the Civic?
17's are better?
So what would be the Ideal size for a 2k1 LX Coupe. 17's or 18's
And what measurements would be good
Old Apr 30, 2003
Bogus1's Avatar
kind of busy at work.....
hope this helps
Tire Calc
Old May 2, 2003
umm yeah dude if you would read my later postings you would see that i meant to say 215-35-18 then i later said i want 17s cuz 18s are too big
Old May 2, 2003
ok so if i go with 17s...i want toyo tires...and the style i want don't come with 205-45-17...and the rims i want are 17x7. So will 205-40-17 or 215-40-17 work with 17x7inch rims? And the rim offset is 40...will that be fine?
Old May 2, 2003
VNlilMAN's Avatar
The Standard One
17s? so small.. even my 18s are small... should go with 19s...
both size tires work with 17s. but imo 205-40-17 is way too thin go with 215-40-17. or 205-45-17
215 is the wide of the tire in mm
40 is the percent of the sidewall compared to the width in other words. 40% of 215 is 86mm
Old May 7, 2003
I like the Motegi Racing MR7's. If I get those I'll prolly get 18's. They are 18x7.5 and offset is +45. Will that work pretty good? Recommended tire size for this wheel?
Old May 18, 2003
Are the bolt cirles for 7th gen civics 4x100/4.5 or 4x100/4.25???
Old May 21, 2003
Are they just 4x100 or is there anything else to it like 4.5 or 4.25?
Old Jun 8, 2003
Does anybody know about the bolt circles? 4x100&4.25 or 4x100&4.5???
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
Wariogamer
Sep 29, 2015 09:49 AM
Balkos
Sep 11, 2015 11:39 PM
