Question about rims
Old Apr 15, 2003
power091999's Avatar
power091999 is an unknown quantity at this point
Question about rims
I recently purchased a set of Giovanna Kobe 17" Rims. I love the rims they look great, and I got a great deal on them 550 w/ tires (used). However I noticed on the front right rim. The inside of the rim has about 8 aluminum weights. I get alot of shake (ON and OFF) when I get up to about 55 = 60 mph. Now I looked over the Rim and it seems as if its not bent. Seems like it's perfectly fine. Could it be a "out of place" belt in the tire itself? Or could it just need to be re-balanced? Any suggestions are appreciated.
Thanks in advance
BTW - Can someone tell me what I am doing wrong with my Sig?
YAY!
vvvvv
Old Apr 15, 2003
BlueBoyCivic's Avatar
"Stage7"
I'm not to sure, but IMO I would get it rebalanced. No wheel should have that much tire weights on it. And as for your sig...try checking the sticky on the Off Topic forum for info...I think it might help!
Old Apr 15, 2003
Spider883's Avatar
9K Redline Owns U
get the tire rebalacned at a local tire shop
Old Apr 15, 2003
Deejai35's Avatar
Deejai35 is an unknown quantity at this point
You should definately check on getting another balance job. That seems like a lot of weights...
Old Apr 15, 2003
666's Avatar
666
666 is an unknown quantity at this point
Do you have hub centering rings on?
Old Apr 17, 2003
Weaponx12o's Avatar
get it rebalanced, and if it still shakes, get centering rings and make sure the tires are properly inflated. if that doesnt work, then i dont know what else you can do.
Old Apr 17, 2003
Macwheels's Avatar
Macwheels is an unknown quantity at this point
Get it rebalanced or check the rim to see if its bent.
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
Inkubus
Wheels and Tires
Aug 13, 2015 05:01 PM
TheRubixHorse
Jul 29, 2015 05:22 AM
afinuf12
Jul 28, 2015 04:44 PM
