wanna fill the gap...
With a 2" drop (Intrax) on a 02 coupe, will 17's with 215/40/17 fill up the gap, or will I need to go with 18's to fill it up? Also, I don't want to have to worry about them rubbing. Any sugg. are appreciated.
I need TP for my bunghole
You will definatly not have a gap with drop.
Just roll the rear fender to be sure that they don't rub the side wall if you use a camber kit.
You might rub in other places though with that drop and 18's. You can use a old wood bat and roll it between the inner fender lip and tire until it is rolled up.
My concept car.
My concept car.
My concept car.
My concept car.
I sure wish my car was newer
Originally posted by Alex053
3 spoke rims went out with pegged pants and denim jackets.
Back to the point.. yes it will fill the gap. But you will definately need a camber kit. Well, unless you like uneven tire wear and replacing them more often than you should have to.
Munzy
21
Oct 7, 2015 07:48 AM
Raiool
Oct 1, 2015 10:42 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
260000milesgoal
Sep 25, 2015 07:41 PM
