widest wheel?
Old Mar 23, 2003
Dr5D's Avatar
widest wheel?
what is the widest wheel we can fit on the front w/o it scraping the car with normal tires? and im sure the back can be wider since it dosent turn. anyone know?
Old Mar 23, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Well.... how much offset do you want?? You can go as wide as you want provided you can keep the wheel from getting too far in. I would think with an offset in the mid 20s you could fit 9" rims on. They'd stick out like hell, but they would fit. I think 7.5" is the widest you're going to want to go... any more than that and you'll probably run into problems.
Old Mar 24, 2003
HondaLuver's Avatar
Its a celebration bitches!
what the hell is up with all the same post?
IBTL
Old Mar 25, 2003
vincenzobar's Avatar
THE WOP
vincenzobar is an unknown quantity at this point
the widest you can go is 215 I had 16 225 and had severe rubbing as well as in the back. I had to dremal the inch fold in the rear fender so my tires fit. I also rubbed to the metal engin frame on the inside front and rubbed away the clamp thingies on the edge of the front wells that hold on the spalsh guard.
215 is as whide as it gets!
Old Mar 25, 2003
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
In the rear, 215 will rub just as much. Providing the car is low enough.
Old Mar 27, 2003
THE WOP
Yeah you might be right. 205 for sure becuase my rear is lower then the tire (no gap) and i am fine with 205s
Old Mar 27, 2003
Nitek's Avatar
Nitek is an unknown quantity at this point
215 fits fine, and I have a 7.5 inch rim with 45 offset and fits perfect. I dont think u can fit any wider in that wheel wheel. My rims stick out more than the tire does, and i have no wheel gap all round and have never had any problems with rubbage. I think 225 will be the biggest you can fit.
Old Mar 27, 2003
Nitek's Avatar
Old Apr 3, 2003
Dr5D's Avatar
yea, i just want regular 15s, like stock, but i want wider - cause wider is better
siliconvalley
Sep 15, 2015 09:48 PM
Wheela
Wheels and Tires
Sep 7, 2015 02:14 AM
JohnDay
Wheels and Tires
Sep 6, 2015 06:42 PM
rainman15
Sep 6, 2015 11:10 AM
