Tires for a 16 in rim
Old Mar 21, 2003
netwrkman5's Avatar
netwrkman5 is an unknown quantity at this point
Question Tires for a 16 in rim
I'm planning to get 16" rims for my car and am planning to get 205/55/16 tires, does anyone know if this tire size is too large. (My car is not lowered, nor do I plan to lower it.)
Old Mar 21, 2003
rino's Avatar
rino is an unknown quantity at this point
get 205/50/16. 55 is gonna be too big and throw your speedometer off.
Old Mar 21, 2003
Frank2sy's Avatar
Frank2sy is an unknown quantity at this point
Use the tire calculator.
Old Mar 21, 2003
Brandon's Avatar
Brandon is an unknown quantity at this point
Get 215/50/16 and your speedometer and odometer will be exactly the same.
Old Mar 21, 2003
oblivious9's Avatar
oblivious9 is an unknown quantity at this point
I just got 205/50/16, 215's may be too wide
Old Mar 22, 2003
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
215 is only too wide if your car is lowered. It will strike the rear fender well. A common problem especially with people who lower their car on 17s. Since he's not lowering his car, it shouldn't be a problem.
Old Mar 22, 2003
BigDaddyHonda's Avatar
BigDaddyHonda is an unknown quantity at this point
Maybe by now you have used the Tire Calculator and seen that 205/55-16 is one of the recommended "Plus One" sizes. Even though that's not the size everyone on this thread (including me) has chosen for their own car, you will be perfectly fine. Actually the fatter sidewall of the 55 series will probably help fill the fenderwell gap since you don't plan on lowering your car. Just remember to factor in your speedometer error when you are driving at higher speeds.
Old Mar 24, 2003
SiGuy's Avatar
SiGuy is an unknown quantity at this point
Hey, check out my ride! I just got 205/55/16s and they don't look too bad. They are slightly larger than a stock tire but up here in Canada the 195/55/16 are impossible to find. They come stock on the new Mini Cooper and are a Goodyear run flat. I don't suggest them because they are 3 times the price of a regular tire. Firestone Fire Hawk GTA-02s are available in 195/55/16. Check it out on the tire calc.!
Old Apr 11, 2003
CivicEnvy2001's Avatar
CivicEnvy2001 is an unknown quantity at this point
If you're planning on buying rims, I'd at least get 17's. Then get 215/40/17 tires. They will look so much better.
Strycker
Aug 18, 2015 02:25 PM
lexus300
Wheels and Tires
Aug 16, 2015 04:31 PM
lexus300
Aug 16, 2015 04:28 PM
Inkubus
Wheels and Tires
Aug 13, 2015 05:01 PM
afinuf12
Jul 28, 2015 04:44 PM
