225/40/18 with GoldLine drop
Old Mar 18, 2003
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
Unhappy 225/40/18 with GoldLine drop
I'm scared....
I just ordered some 18's w/ 225/40/18 tires and I was wondering if i'm gonna have any problems (rubbing) when I slap them on. I am dropped with GoldLine (it's not even that low) and before i was running 205/40/17 and there was still alot of wheel gap with the 17's.
Is anyone else running 225/40/18 with a drop?
Old Mar 18, 2003
DizWikedCivic's Avatar
225 is to thick, even 215 is kinda thick, i have 205/40/17 w/ a 2.75 drop w/ no rubbing
Old Mar 18, 2003
GanariGuY's Avatar
GanariGuY is an unknown quantity at this point
thick is good if u live around bad roads..... save you from alot
of damage to ur rims
Old Mar 18, 2003
yea good for the road but not good for lower cars
Old Mar 18, 2003
Unleaded's Avatar
Unleaded is an unknown quantity at this point
he's got no choice, with 18" you have to go with 215 minimum (they don't make 205/18 for a reason). i'd go with 215/40/18 to be safe.
Old Mar 18, 2003
CivicSouldjaEX's Avatar
205 is way to thin, the tire wouldn't be able to sit the bead on the wide rim. 215 still kinda looks funny, the best would be 225 but then again, with the goldline drop, it might rub.
Old Apr 11, 2003
CivicEnvy2001's Avatar
CivicEnvy2001 is an unknown quantity at this point
225 is too thick. You'll probably have alot of rubbing with it dropped with goldlines.
Old Apr 11, 2003
205, have a 2.75 drop, no rubbing
Old Apr 30, 2003
noahnoah's Avatar
noahnoah is an unknown quantity at this point
so without a drop you should be good with that tire size?
Old May 1, 2003
VNlilMAN's Avatar
The Standard One
205-40-17 vs 225-40-18 is a night and day difference..
its about 1.25" bigger. with goldlines you WILL RUB. 225-40-18 is just too thick... even without a camber kit you probably have to roll your fenders. correcting camber, you can forget about it.
Old May 1, 2003
noahnoah's Avatar
okay....who are these guys saying that they will fit and that they have them on their rides??? anyone? I want to know from someone who has 225/40/18s on their ride, how well they fit or IF they do. I believe you VNlilMan, but I don't understand why all these other guys would say they prefer that size tire over another tire??
Old May 1, 2003
slystad810's Avatar
IMO 215/40/18 is a better choice. 215/35 is too thin for the roads around here and 224/40 is just huge.
Old May 1, 2003
Bogus1's Avatar
Bogus1 is an unknown quantity at this point
I'm pretty sure something like this was covered try to search. I know a thread that talked kind of on your subjest.
Old May 1, 2003
Frank2sy's Avatar
Frank2sy is an unknown quantity at this point
I have 215/45/17 series tires with Goldline drop. My rear tires rub against rear fenders when going over bumps, because 215 series tires are too wide for Civic's rear wheel well. With 225 series tires, you are going to have a hell lot of rubbing.
Old May 2, 2003
VNlilMAN's Avatar
The Standard One
well ok i'll admit i havnt been explaining everything too well so here it is... there are alot of variables to take into account when trying to see if something rubs or not...
1) size of tires and rim(obviously)
2) amount of drop(again thats obvious)
3) offset(it might be in mm but still makes a difference)
4) tire brand. its like shoe size, not all brands have the exact same size. its around that ballpark but not exact. you might be a size 10 in nike but a 9 in reebok. same with tires, some tires are slightly bigger then others even when their tagged the same size.
5) alignment...you drop 5 stock cars with goldlines. chances are none of the cars are going to have the same exact alignment.
i have 215-40-18s.. my tires are even bigger than Frank2s's 215-45-17. i have neuspeed drop as well, i've hit bumps pretty hard, even parked on hills where my tires would tuck all the way. i had no problems with it rubbing at all.. this just shows, no car is exactly the same as another.
generally speaking 225-40-18s, you will rub. why would you want to anyways.. even 215-40-18s are pretty thick. if they are still too thin for you i would recommend you get 17s. i personally would try and get 225-35-18s next time tho, my 40s are too thick and 215-35-18s are too thin. 225-35 just seems like the perfect size. but ya you might rub, its a chance i'm willing to take. you can always make it fit...
Old May 2, 2003
FALKEN's Avatar
Civicforums Junkie
well said VNlilMAN
Old May 19, 2003
blucivic's Avatar
blucivic is an unknown quantity at this point
I just bought 18x7.5" wheels. I put on 225-40-18 perelli tires. I got the nuespeed race springs and my rear wheels did rub....but then I got the fenders rolled and now im fine no more rubbing. I perfer the 225-40-18 because there are a few bumps around my neighborhood...if you go ewith those tires....just roll your fenders.
Old May 19, 2003
2k2EXCOUPE's Avatar
TUCKIN 19s
My friend has a 02 civic coupe on goldines with 225/35/18. NO RUBBING.
Old May 19, 2003
ViNRoCk8's Avatar
#1 S2000 Fan
Does he have a camber kit and is his car alligned?????
Thanks bro
Old May 20, 2003
UpNorth2k1's Avatar
UpNorth2k1 is an unknown quantity at this point
There is a member here, Topfuel. he has 225/40/18 and has goldlines and a bodykit. I would like to know if he rubs or not.
Old May 20, 2003
CivicBR900EX's Avatar
Master
CivicBR900EX is an unknown quantity at this point
my 225/40-18 rubbed!
Tedverseti
Sep 29, 2015 05:41 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
Hollywoodsnake
Sep 20, 2015 12:58 PM
Juanb24
Sep 15, 2015 12:39 AM
