Yokohama Parada Spec 2
Old 03-02-2003
Shlomo's Avatar
Shlomo is an unknown quantity at this point
Hello all
I just bought these and had them placed on my car about a week ago. Yesterday i was sitting behind my car and i noticed the right and left wheel wasn't symentrical. For example, the think line that is on the tire is towards the outside the car on both sides but the tread on the left tires faces the opposite direction as the tires on the right side. I hope someone understands, if not back to where i bought them.
Thanks for all your help[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Shlomo
Old 03-02-2003
666's Avatar
666 is an unknown quantity at this point
Sounds funny.....maybe they mounted them wrong.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old 03-02-2003
UBLOOKN's Avatar
UBLOOKN is an unknown quantity at this point
if i was u i would take it to my local tire shop and see what they say about it... cause that could be a serious problem
Old 03-02-2003
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
hrmm, sounds wrong to me.
Could it be something like you have 4 right side tires?
Old 03-03-2003
slystad810's Avatar
I used to have them and it's normal. If you look on the sidewall of the tires they should all say "Mount this side out" or "outside". The reason they look like that is they are an asymmetrical tire.
Old 03-03-2003
BigDaddyHonda's Avatar
BigDaddyHonda is an unknown quantity at this point
Yeah, Shlomo, go outside and check out the sidewalls...somewhere on there Yokohama has written "this side facing out" so if you see that, you are OK.
That would make the long line and "dots" face the outside on both sides of the car, so I think Shlomo is okay. Let us know [IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old 03-03-2003
djmota's Avatar
as long as that thick line in the tread is facing outwards on all 4 You are fine.
I just recently got a set and wondered the same thing for a few minutes.
Old 03-04-2003
Shlomo's Avatar
i just went and checked the tires. All 4 tires said this side outwards, so i guess i'm cool. They just look kind of weird though. Guess they are just supposed to be that way. Well thanks for everyones help.
Shlomo
Old 03-04-2003
Falcon's Avatar
Falcon is an unknown quantity at this point
they are asymmetric tyres
just make sure when you rotate them you dont actually rotate them just switch front with rear
Old 03-05-2003
slystad810's Avatar
Quote
[hr]Originally posted by: Falcon
just make sure when you rotate them you dont actually rotate them just switch front with rear[hr]
Doesn't matter, they are asymmetrical, not directional.
Elciteeve
09-28-2015 12:40 PM
fvckbg
09-08-2015 09:55 PM
thaler4cuse
09-07-2015 08:25 PM
WaryDriver
08-22-2015 06:50 PM
07-12-2015 11:54 AM
Quick Reply: Yokohama Parada Spec 2
