rear wheel disc brakes
Old Feb 11, 2003
hondamexicano's Avatar
hondamexicano is an unknown quantity at this point
I was wondering if anybody has installed rear disc brakes on their cars? How complicated is it to switch the drums?
I´ve been wondering if it would be worth installing rear disc brakes on my civic EX. For example, adapting them from an Accord EX 4 cyl.
Is it a bolt off bolt on procedure? How would it affect my ABS? How much can it cost?
Old Feb 11, 2003
white2K2EX's Avatar
I sure wish my car was newer
I can't answer most of what you asked. But I can tell you you're going to pay a WHOLE lot to do the conversion.
Old Feb 11, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
I don't know about an accord... I suppose if the hubs and spindles fit you could do it, but you'd need new rims too (bolt pattern).
Easiest way is to get them off an EP hatch. As far as the swap procedure, I don't know. Maybe you can just bolt on the entire lower control arm. I'm not sure, I haven't researched it all that much, but it's something I'd like to do in the future.
I know you need the discs, calipers, lines, e-brake cables, hubs and spindles at the least to do the swap. I'm not sure what else. Maybe you can see if AEM or Wilwood or someone has a PDF file for installing them on a 6th gen, just to get an idea of what the conversion involves... but it won't be the same for ours.
Old Feb 12, 2003
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
ssbrakes.com has rear disc conversion (and big brake front) for like $700 or $800 it has 12" rotors and comes w/ the calipers in any color. jus a thought only thing is you have to have 16" or bigger wheels to fit them in
Old Feb 13, 2003
Thanks,
I´ll check ssbrakes. I have 16 inch rims, so there´s space in there for something bigger. Looks like it´s kind of complicated, I though this could be a bolt off - bolt procedure. Probably not worth it, it would be better to just upgrade the front brakes.
and actually I think my brakes are good, the problem I have is that they wear out extremely fast. My car has 18K kilometers (about 13k miles i think) and it already needs new shoes and pads for the second time (I drive up and down hill and over many speed bumps, which explains why they don´t last. Maybe just getting better shoes instead of the oem ones...
Old Feb 13, 2003
aki's Avatar
aki
aki is an unknown quantity at this point
If you get a hookup its not that expensive. My friend offered me to do it at his cousin's place for like $300.
-Aki
Old Feb 14, 2003
Rider's Avatar
Rider is an unknown quantity at this point
Quote
[hr]Originally posted by: aki
-Aki[hr]
GO FOR IT
Eric
conspiracy90
Jun 7, 2023 01:01 PM
edspyhill09
Jun 12, 2016 02:45 PM
Optimus34
May 25, 2015 11:52 PM
rhvic
May 22, 2015 03:06 PM
Broadbeb
May 14, 2015 09:49 PM
