lug pattern
Old Feb 9, 2003
david02civic's Avatar
I'm The Shit
david02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusted
lug pattern
what is the lug pattern on my car(2002 civic DX coupe)is it 4x100?
Old Feb 9, 2003
Sweetpants's Avatar
Sweetpants is an unknown quantity at this point
yes
Old Feb 9, 2003
4bangin's Avatar
yup 4x100
Old Feb 9, 2003
SOHC's Avatar
I spent 1425 points to do this.
SOHC is an unknown quantity at this point
ahh, now that weve got that clear, lets talk about wheel offset. i dunno anything about it- except that common ones are 40, 43, and 45. which is best for our cars? consider tire rubbing and a flush-to-body fit
Old Feb 10, 2003
ZMan2k2's Avatar
The Man, Myth and Legend
From: Western Canada, where the beer is cold and the women are HOT!
ZMan2k2 is an unknown quantity at this point
I read a thread on here, I think last week, and most of the senior members were saying 45 is the best offset, to avoid rubbing and still keep fender clearance on lowered cars. I'm too lazy to do a search, but I think it was in "Wheels and Tires" forum.
Old Feb 10, 2003
666's Avatar
666
666 is an unknown quantity at this point
It depends on the width of the rim too.
Old Feb 14, 2003
YS's Avatar
YS
YS is an unknown quantity at this point
is it 45 or 42 ?? using 18x7.5 w/ 215/40/18 ?????
Old Feb 14, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
IBTL
search next time
Old Feb 17, 2003
Grey's Avatar
DIY King
Actually... For the offset it depends on the width of the wheel and tire. Certain width wheels can accept certain width tires. My wheels are 17x7 and the largest width of tire that they can accept is 215. The offset happens to be 45 and in front that is perfect. No rubbing of any kind and I have a ton of room inside, so I could actually fit something like a 225 with a 40 offset. The smaller the offset, the more the whole wheel sits inside the fender. The larger the offset the larger the wheelbase. For my wheels, and stock ride height the rear can't get any bigger in width. That's why I'm making custom rear lower control arms. [IMG]i/expressions/demon.gif[/IMG]
Old Feb 17, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Quote
[hr]The smaller the offset, the more the whole wheel sits inside the fender. The larger the offset the larger the wheelbase.[hr]
You've got it backwards... The lower the offset number, the closer the mounting surface is to the centerline of the wheel, thus pushing the outer edge further out. Larger offsets pull wheels further into the fender since the mounting surface is farther outside of the rim centerline. It also does depend on the width of the rim how far they'll stick out. You can probably go down as far as 38 or so with a 7" rim and still not have them sticking out.
The way you have it explained works for negative offsets.... but we've got positive offsets.
Old Feb 18, 2003
Grey's Avatar
DIY King
Whoops! You're right. I always get thinks backwards. Aw hell, just look here: Wheel Tech: Offset
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
General DIY
Sep 25, 2015 08:02 PM
siliconvalley
Sep 15, 2015 09:48 PM
h4ldol
Sep 10, 2015 12:25 PM
