Stupid ABS
Old Feb 6, 2003
HCivic02's Avatar
"Stout"
HCivic02 is an unknown quantity at this point
Stupid ABS
whenever i start to brake going down a hill it seems like my abs kicks in because my car will make a sudden jolt forward. has anyone else had this problem. i took it to honda whenever i first got the car and they said we cant find a problem with it
Old Feb 6, 2003
solar's Avatar
solar is an unknown quantity at this point
Just a question but are you applying constant pressure on the brake pedal while going down the hill? Its possible that the brakes are heating up and grabing, but normally just the oposite happens; the brakes heat up and fade. Do you hear the ABS module clicking under the hood and does the brake pedal pulsate? If you don't the ABS isn't activated so at least you know its not a problem with the ABS, but if you do than it could be a problem with it. I'd take it back to the dealer and have a tech ride with you and show them first hand what happens.
Are you from Lakeland FL? Where is there a hill in Lakeland?
Old Feb 6, 2003
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
iono man...[IMG]i/expressions/face-icon-small-confused.gif[/IMG] I never had that problem. My ABS only kicks in when I step on hit hard!! Its saved my life quite a few times though, or at least saved me from accidents... Maybe it'll help if you downshift + brake at the same time...
Old Feb 6, 2003
VNlilMAN's Avatar
The Standard One
my lx does that too sometimes.. kinda making it feel like i'm slamming on the brakes when i'm not.
Old Feb 6, 2003
HCivic02's Avatar
"Stout"
whenever it does jolt it is usually right after i puch the brake pedal and i havent noticed a clicking sound or if the pedal pulsates and yes i am from lakeland florida and most of the hills i am on are in tampa since i work there
Old Feb 6, 2003
ZMan2k2's Avatar
The Man, Myth and Legend
From: Western Canada, where the beer is cold and the women are HOT!
ZMan2k2 is an unknown quantity at this point
I had that problem too. Is your car an automatic? Because I took mine to my dealer, showed him and I had mine explained to me. With the overdrive autos (4 gears) the torque converter will lock, to increase fuel mileage. When you step on the brake, the lock releases, and there is that sudden jolt, when the tranny drops a gear, from 4th to 3rd. If you have an auto, don't worry about it, apparantly it's normal.
Old Feb 6, 2003
Friedrice's Avatar
Friedrice is an unknown quantity at this point
When I first bought my car, even after the break-in period for the breaks, it seemed like ABS would kick in occasionally under light breaking in non-slipperly condionts. After I bought my 17in tires, hasn't happend expect when its supposed to.
Old Feb 7, 2003
BigDaddyHonda's Avatar
BigDaddyHonda is an unknown quantity at this point
If your car is an automatic, Zman2k2 is probably right--the jolt you feel is your tranny downshifting into a lower gear when you tap your brake. This especially happens when you top a hill and slow down for a turn-off.
Next time take a look at your tachometer the very second you feel that jolt start to happen. Hopefully you'll see the revs jump and that will prove this. If so, you are OK.
If you have a 5-speed, ... [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 10, 2003
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
Like it was said before. If your car is an auto it will make that jolting sensation when going down a hill and braking. It feels kid of like a small downshift in a 5 speed or something. Its not the brakes its the tranny, its is meant to do that as well, I am not sure if the purpose is to save fuel, or help assist in the braking or what, but it is meant to be there and is common.
h4ldol
Apr 24, 2017 08:16 PM
JetsterDajet
52
May 8, 2016 12:11 AM
alaga
Feb 28, 2016 02:19 PM
Inkubus
Wheels and Tires
Aug 13, 2015 05:01 PM
