Max width tires on OEM rims?
Old Feb 2, 2003
nudiepix's Avatar
nudiepix is an unknown quantity at this point
Its about time to replace the tires on my EX and was wondering how wide a tire I can put on the stock 15s without having any adverse effects. I found a set of Yokohama AVS Intermediates in 205/60/15 for cheap and was wondering if they would fit without any problems.
Thoughts?
Old Feb 3, 2003
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
i think you can only put 1 width tire on a certain width rim
Old Feb 3, 2003
nudiepix's Avatar
Normally, each rim width is capable of being fitted with multiple tire-widths... I wouldn't suggest going up more than 20mm or so, I assume that the sidewall can only flex so much to accomodate the different width rim before sidwall flex is affected too much (and perhaps the tread flexes too much).
According to michelin, actually, they suggest 195/60/15, 195/65/15, or 205/60/15...at least according to them I should be fine.
Old Feb 3, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
You can use 205s on the stock rims... There are people on here who are driving on them with no troubles.
Pudnite
May 9, 2015 07:51 PM
bo_red
Apr 23, 2015 10:09 PM
klam
Dec 1, 2001 10:17 PM
technosilver
Nov 14, 2001 10:58 AM
