WILL I RUB
Old Dec 16, 2002
grn2k1's Avatar
grn2k1 is an unknown quantity at this point
WILL I RUB
Hey i am trying to decide what springs i should get. I have 215-35-18 tires. and i want the neuspeed race springs. will i be able to have the correct camber if i get camber kits front and rear and will i rub at all with the correct camber and allignment. thanks for your help
Old Dec 16, 2002
alex053's Avatar
Im looking at the same set up. someone help us out.
Old Dec 16, 2002
VNlilMAN's Avatar
The Standard One
DO IT!!! i wish i had that.. not sure if you'll have any problems with it rubbing or not with a correct camber but i think you should be fine. if not, roll them a little or keep a slight negative camber.. i think the rear cambers spec range is anywhere from +.5 to -1.5 so if it does rub, adjust it to -1.5 degree and i'm sure you'll be fine.
UltraHDGames
Jun 8, 2016 05:16 PM
cukaracha
Aug 29, 2015 05:27 PM
Pudnite
May 9, 2015 07:51 PM
2Hottie
Detailing
21
Jun 18, 2002 09:39 AM
soljahboy17
Apr 1, 2002 03:24 PM
