Quick Q, what does offset mean?
Old Dec 2, 2002
sumama's Avatar
sumama is an unknown quantity at this point
I read that the offset for our cars is +42mm, but will rims with +38mm or +40mm fit ?
Old Dec 2, 2002
white2K2EX's Avatar
I sure wish my car was newer
I can't answer your question about what will fit other than 42. But on many cars, the wheel will not fit if the bolting part is right in the center of the wheel. So an offset basically sets the wheel off-center so it will not interfere with the body of the car or rub.
Old Dec 2, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
Offset is the distance (in mm) from the centerline of the rim to the mounting face of the rim. Positive offsets pull the wheel further into the fender well, Negatives (you don't want these) push the rim out. +38 or +40 should be perfectly ok... you'll be pushing the rim out a little further (2 mm isn't even noticable) But don't forget that the rim will also get wider. Offset is related to the rim you are putting on, not the stock one. So a 40 mm offset on a 7" rim is not going to push it as far in as a 6" stock rim. If you're going with a rim that has a lower offset number than stock, take the difference in offsets, convert it to inches (2.54 mm=1") then add it to 1/2 the difference in rim widths
New Rim - Stock Rim
That will tell you how much further the rim will stick out. With a 38 offset on a 7" rim, it'll stick out about 5/8" further than stock. You should still be ok... I just measured (very rough guess) but from the face of my stock rim (00 Si) to the farthest point out on the top of the fender there is about 1.5" difference. So it shouldn't stick out.
UltraHDGames
Jun 8, 2016 05:16 PM
ricer_em2
May 11, 2016 08:09 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
metalpres
Sep 23, 2015 05:22 AM
JohnDay
Wheels and Tires
Sep 6, 2015 06:42 PM
