What is offset??
Old Oct 21, 2002
fatboy's Avatar
fatboy is an unknown quantity at this point
What is offset??
Just wanna know if someone can define what offset is. I hear bout it all the time, but I am not sure how it affects/relates to our cars. Also, if someone could tell me what is the stock offset and what the recommneded offset (if any) is for aftermarket wheels. THANK YOU! [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Oct 21, 2002
impetigo's Avatar
impetigo is an unknown quantity at this point
From 1010tires.com:
Offset
The offset of a wheel is the distance from the mounting surface of the wheel to the true centerline of the rim. A positive offset means the mounting surface of the wheel is positioned in front of the true centerline of the rim / tire assembly. This in effect brings the tire in to the fender well more. Conversely, a negative offset means the mounting surface of the wheel is behind the true centerline of the rim / tire assembly. This will cause the tire to stick out away from the vehicle.
everything you wanted to know about wheels but were afraid to ask
Old Oct 21, 2002
fatboy's Avatar
Quote
[hr]Originally posted by: impetigo
From 1010tires.com:
Offset
everything you wanted to know about wheels but were afraid to ask[hr]
well.....i was STILL wondering [IMG]i/expressions/face-icon-small-confused.gif[/IMG] what offset will look good/safe for a 18X7.5 wheel and a standard low pro tire with a 40 sidewall
Old Oct 21, 2002
impetigo's Avatar
i've been wondering the same thing today and ppl seem to be saying that the offset should be 40-45, but that 40-42 is ideal. but that was for 17" wheels and tires, for 18" maybe 45 would be better but prolly 42 or so will be fine.
UltraHDGames
Jun 8, 2016 05:16 PM
JohnDay
Wheels and Tires
Sep 6, 2015 06:42 PM
greentoaster
Sep 1, 2015 12:18 AM
Strycker
Aug 18, 2015 02:25 PM
