Rear brake shoes
Old 10-12-2002
JumpingBean's Avatar
JumpingBean is an unknown quantity at this point
Rear brake shoes
Anyone replace these yet? I dont have a clue how to do it. I need some help. Dont know how to get to the rear shoes.
Old 10-12-2002
1955's Avatar
remove the wheel,hub cap(in center) with a flathead,raise the stake and remove the spindle nut,screw two 8x1.25 mm bolts into the drum to push it away from the hub,turn each bolts 2 turns at a time to prevent cocking the drum excessively,remove the drum and hub bearings unit from the spindle.next question?
Old 10-12-2002
Sweet thanks!
Old 10-12-2002
EternalVTEC's Avatar
EternalVTEC is an unknown quantity at this point
theres more to it than that, get a shop manual like the one from Chilton's, thatll help a lot, drums are more complicated than discs.
Old 10-12-2002
1955's Avatar
ok, here is the rest.. remove the tension pins by pushin each retainer spring and turnin the pins,,remove the lower return spring and remove the shoe assembly over the hub,, remove the upper return spring and disassemble the brake shoes,disconnect the parking brake lever and remove the shoes..remove the U clip.wave washer and pivot pin and seperate the parkin brake lever from the shoe and thats it!!!!!
rtachs
07-16-2015 05:32 PM
DAC
06-18-2015 10:00 PM
bsmiley
04-27-2015 01:27 PM
CivicHX01
25
11-18-2003 09:40 PM
Andy
12-29-2001 07:32 AM
Quick Reply: Rear brake shoes
