brake fluid
Old Oct 2, 2002
slowasscivic's Avatar
slowasscivic is an unknown quantity at this point
brake fluid
hey i just purchased brembo rotors and aem pads. i am going to install them and i was wondering if i should also change the brake fluid. would it make a difference going to a better brake fluid with my new rotors and pads? i heard good things about ATE Super Blue Racing Brake Fluid. ne1 else know if that is good stuf or what? any suggestions?
Old Oct 3, 2002
CapYoda's Avatar
Escaped Convict
I heard those are good stuffs.
I'll suggest not using ur new rotor and pads at the same time...
its been said that you should use the old pad with the new rotor OR, the old rotor with the new pad.
its probably best to do the new pad with the old rotor and then when its worn in a bit, slap on the new rotor.
Old Oct 3, 2002
Grey's Avatar
DIY King
Quote
[hr]Originally posted by: CapYoda
its probably best to do the new pad with the old rotor and then when its worn in a bit, slap on the new rotor.[hr]
I hear people say it both ways. I have no clue who's right? I installed my new rotors and pads at the same time and I think my brakes appear to be none the worst for wear.
Old Oct 19, 2002
1jazzyciv's Avatar
1jazzyciv is an unknown quantity at this point
I agree with GREY - I installed them together and they seem to seat well with each other and work very well. I have not drained and re-filled the system with BLUE yet but I plan to - will probably do it with the new braided lines when I go that route. Factory fluid is fine for a good many miles and unless you enjoy bleeding the lines and have some help I don't think you'll see that much added value.
JASON
Jul 12, 2015 11:54 AM
OptimisticWay
Jul 10, 2015 04:31 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
General 7th Gen
Jul 9, 2015 10:17 PM
Causemo
Jul 5, 2015 06:42 AM
