Big Brake Kit question
Why is AEM changing their rotors to black? You can't notice them as much, and wouldn't look good. Does anyone know a brake kit with oversize rotors that doesn't cost alot?
Allegedly (SP) AEM says that the changes care made for the better...1-piece design for better construction than a 2-piece rotor..black because its a new anti-rust process that is a lot better than what they had before (copied from Rotora rotors I believe) and went to slotted only becuase they belive slotted and drilled weakens the construction of the rotors. Wilwood has a brake system too for our rides but dont know how much. Hope that helps
personally, i think the new black AEM big-brake kit looks cool. the Wilwood Big Brake kit w/ 4piston caliper was detailed in the latest SCC where it is installed on a 7thgen civic, they also installed stainless steel braided brake line. very nice, but the Wilwood kit would probly cost like $1000-1200 or more (thats what AEM's big brake w/ 4piston caliper kit costs).
i think the Wilwood big brake kit does come with 4-piston calipers by default, but the AEM "Big Brake Kit" doesnt, for that you need the "Big Brake Kit w/ 4-piston Caliper" which is sold as something else.
The cheapest Wilwood big brake kit i found was at summit racing and they sell it for a little over 600. The rotor size is 10.25. Not as big as the AEM rotors are. But thats a good price for have a 4-piston caliper. Usually they are over 1000 dollars.
555, are you sure that was the one with the 4-piston calipers...i thought the Wilwood big-brake kits only come with the nicer calipers, but thats hella cheap if it is!
EDIT: i just found the product you were talking about, and it looks like its the real big-brake kit with the 4-piston calipers...wow, thats a kickass price
only $150 or so more than the AEM big brake kit that uses the stock calipers
DIY King
For those without the magazine here are some good articles:
Civic How-To: Install Wilwood Big Brakes
Wilwood Big Brake Upgrade
7thgensurvivor
38
Aug 29, 2015 11:50 AM
97-DX-Lover
Jun 14, 2015 06:07 PM
JohnnyBxo
16
May 9, 2015 05:53 PM
