40 offset + 17" rims = rubbing?
Old Aug 24, 2002
pmau's Avatar
pmau is an unknown quantity at this point
I was planning to get some 17" rims w/ 205/40/17 tires, but the offset of the rims are 40. I also have eibach sportlines installed. So I was wondering if this combo with equal to rubbing?
Old Aug 26, 2002
nytejade's Avatar
nytejade is an unknown quantity at this point
You'll probably be all set with 215/40/17
Old Aug 26, 2002
Briareos's Avatar
Briareos is an unknown quantity at this point
I was going to get some yokohama parada spec-2 215/40/18's , but the guy at discount tire said they would probably rub... if not, they would have very little clearance.
Old Aug 26, 2002
nytejade's Avatar
I have Yokohama Parada Spec 2's on my wheels. 215/40/18. They rub with Neuspeed Sport Springs. Well, I haven't gotten an alignment. Either that will fix the rub or make it worse. It only rubs on one side now. You can bend the inside of the fender though to escape that. That's what I"m going to have to do.
Old Aug 26, 2002
yittleblackcivic's Avatar
yittleblackcivic should not be trusted
my man who owns a shop has racing hart c2 evos with the prokit on 215/40/17 and he don't rub...?????[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Aug 27, 2002
nytejade's Avatar
Of course not. I barely rub and I'm on 18's (215/40/18). His wheels are an inch smaller. A lot of people don't notice rubbing on their 18's because A) They never listen for it, B) They lower their car and never get an alignment. So they end up with a lot of negative camber, making the fender lip miss the wheel. I bought a rubber mallet today. I'm just going to take the blow gun and the mallet to it tomorrow. [IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Aug 27, 2002
Guest
Guest
Posts: n/a
im running 215/35/18 with neuspeed sport springs up front and neuspeed race in the rear. fully alignened but only a camber kit up front. no rub at all.
Old Aug 27, 2002
nytejade's Avatar
If you put race springs in the rear and didn't get an alignment I can almost assure you that you're getting negative camber back there. That, and the 35 side wall is why you're not getting rub. I have 40.
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
Wariogamer
Sep 29, 2015 09:49 AM
Balkos
Sep 11, 2015 11:39 PM
