slicks
True slicks have no tread, thus are not DOT approved. There are DOT Slicks and drag radials. This one sucks. This one I like. There are others, but you get the idea. There's one from Nitto (NT 555R Drag Radial) and although not technically only for drags there is the Yokohama A032R that is used by some for drag racing, as well as track and road courses. Most sport compacts that are at the drag strip cannot take advantage of a true slick. So drag radials are generally the way to go. Hope this was helpful.
Edit: prices range. $112 is the cheapest I've seen them. The one I would use runs about $125 in my size.
the usefulness of slicks or even drag radials on our cars is kinda pointles.s. the added grop off the line will only cause your clutch to slip... just some good performance tires are all that's needed..
HISPAnIC CAUSIn PAnIC
Quote
[hr]Originally posted by: mohawkboom
the usefulness of slicks or even drag radials on our cars is kinda pointles.s. the added grop off the line will only cause your clutch to slip... just some good performance tires are all that's needed..[hr]
Quote
[hr]Originally posted by: sadboy619
thats why i posted before i bought them[hr]
Quote
Quote
sf3r8z
Aug 11, 2015 02:32 PM
