Someone with knowledge
Old Jul 11, 2002
Unomyname's Avatar
Unomyname is an unknown quantity at this point
I know we have people on here that know alot so....this guy is selling some 215/40/r18 konig monsoons off his 92 nissan altima...will they fit my car???? should i get 40s??? is that too big???
Old Jul 11, 2002
dezod's Avatar
7thgen Power Maker
you can cram 19" on a 2k1 civic. as long as its 4 lug pattern. yur fine!
Old Jul 11, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Quote
[hr]Originally posted by: djlutchi
you can cram 19" on a 2k1 civic. as long as its 4 lug pattern. yur fine![hr]
not true. The bolt pattern HAS to be 4x100mm.
The offset has to be somthing like 40 to 45mm. I'm not sure on the offset range, could somebody else verify this.
Both Tire Rack and Discount Tire do not have listings for a '92 Altima. They DO have listings for '93 Altima's. Almost all the wheels they recommend have a 4x114.3mm bolt pattern. My informed guess is that those wheels will not fit.
EDIT: If the wheels have a dual bolt pattern (ie: 4x100 / 4x114.3), then you're good to go!
EDIT (again): Check out this website Konig Monsoon. It says the dual bolt pattern is both 4x100 and 4x114.3. Safest bet would be to do a test fit, or maybe even e-mail/call Konig and ask.
Konig Website
Old Jul 12, 2002
ToddatDiscountTireDirect's Avatar
ToddatDiscountTireDirect is an unknown quantity at this point
This should not be a problem for you at all. If he has an older Altima it is a 4-114.3 bolt pattern. The Monsoons should be dual drilled 4-100/4-114.3. The exact same PN from Konig fits both cars...m078d0445s. Be careful not to bust one up, you can't find those anymore!
Old Jul 12, 2002
Unomyname's Avatar
thank you for all your help....i really needed it..
Laucard
Sep 18, 2015 07:11 AM
redcloud
Sep 7, 2015 01:45 PM
Wheela
Wheels and Tires
Sep 7, 2015 02:14 AM
tomas6791
Aug 22, 2015 12:20 PM
mrwhos
Aug 11, 2015 02:03 AM
