Changing Lug Pattern???
Old Jun 25, 2002
EXChris2001's Avatar
EXChris2001 is an unknown quantity at this point
I know our cars have a 4x100 lug pattern, but my friend has some awesome rims with almost brand new tires that he will sell me really cheap. They are a different lug pattern though. My question is is there any way to change the lug pattern to fit a different rim. Can I replace the part that has the lug pattern on it or is what I want totally impossible.
Old Jun 25, 2002
2001CivicEx2dr's Avatar
2001CivicEx2dr is an unknown quantity at this point
I don't know the details, but they do exist. Very expensive, though and not really worth it from all I've heard.
Old Jun 25, 2002
maverickja17's Avatar
maverickja17 is an unknown quantity at this point
You can do it, but it is a bit cost-prohibitive. By bit I mean a lot.
Old Jun 25, 2002
xPiReD's Avatar
xPiReD is an unknown quantity at this point
Not totally impossible but expensive and time consuming. You would have to have the rotors and drums drilled for the new pattern, assuming there is metal where the holes need to be drilled, and new studs pressed in. All of this would have to be accomplished at a competent machine shop. You couldnt just drill them out with a hand drill. I personally wouldnt waste my time. [IMG]i/expressions/beer_yum.gif[/IMG]
Old Jun 26, 2002
slikor's Avatar
slikor is an unknown quantity at this point
it certainly would be possible, but [if done correctly] it would most likely cost almost as much as buying some sweet rims brand new
Old Jun 27, 2002
BlackSI's Avatar
BlackSI is an unknown quantity at this point
yeah it cost a lot, but you could use wheel adapters but then you'd notice a change in your ride (rides different, not a good different) cuz i did that long time ago same situation as you and I ended up sellin the wheels
Old Jun 27, 2002
ZRPM's Avatar
ZRPM is an unknown quantity at this point
Changing the pattern may cost you more than you save on the wheels. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Oct 18, 2014
Mad Scientist's Avatar
Mad Scientist is an unknown quantity at this point
Re: Changing Lug Patterns
Minette Enterprises in Dallas, Tx 972-241-7184 minette-enterprises.com can remachine your wheel lug pattern for $60 each. They also bore wheel center bores, redrill axles,rotors and brake drums. They can also change the number of lug holes in a wheel or axle.
doncarbone
Jun 8, 2015 03:37 PM
cmart1209
May 29, 2015 04:52 AM
Ninetyatecivic
May 9, 2015 07:48 PM
GabberHead
Nov 1, 2001 02:28 PM
