rust on rotors ?.
Old Jun 5, 2002
nymbus2k's Avatar
nymbus2k is an unknown quantity at this point
rust on rotors ?.
i just checked my front rotors today and found that there was rust on them .
do any of you also have this problem ?. is there any way to remove the rust ?... can i sand it off ?
Old Jun 5, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
Yeah, when I painted my rotors/calipers I saw a thin layer of rust...this is normal...I just basically took some steel wool, and a special fluid that I got @ Pep Boys called "Rust Gone" which basically removes the rust component...then I slapped on some quality high temp paint; no more rust!
2Hottie
Old Jun 5, 2002
trevor's Avatar
trevor is an unknown quantity at this point
Yep, same problem here too.......I'm just gonna wait and get a big brake kit,.......
then.....no more rust
[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Jun 5, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
How often do you drive your car? Rust from just sitting overnight should be nothing to worry about. The next time you brake should take this oxidation off in an instant. Totally normal.
Now if your talking big ugly crusty barnacle-like rust, I'd be worried.
Old Jun 5, 2002
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
just put some water on it and there, u will have a layer of rust.....after i got mine aftermarket brake kit..no more rust on the rotors[IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old Jun 5, 2002
Grey's Avatar
DIY King
I upgraded my front brakes with zinc coated rotors. No more rust. Well, at least on everything but the part of the rotor in contact with the brake pads. If that sits without use for too long it gets a thin layer of rust on it too.
Old Jun 6, 2002
TEKNIQ's Avatar
TEKNIQ is an unknown quantity at this point
Quote
[hr]Originally posted by: Grey
I upgraded my front brakes with zinc coated rotors. No more rust. Well, at least on everything but the part of the rotor in contact with the brake pads. If that sits without use for too long it gets a thin layer of rust on it too.[hr]
Yeah I got mine for $100 from RaceConcepts.....Hey Grey this is where you got yours right?????
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] IMAG0020.JPG (37 Kb)
Old Jun 6, 2002
2Hottie's Avatar
Was it easy for you guys to replace your rotors with aftermarket ones? I wanna do that, but I want to see if it is easy enuff to do myself...
2Hottie
Old Jun 6, 2002
Grey's Avatar
DIY King
Quote
[hr]Originally posted by: Tekniq
Quote
Yeah I got mine for $100 from RaceConcepts.....Hey Grey this is where you got yours right?????[hr]
Yes, but I hear that yours are a different pattern than mine. Less holes and straight slots. Weird.
Quote
[hr]Originally posted by: 2Hottie
2Hottie[hr]
Try my DIY:
Rotor and Brake Pad Install
Also, check out the DIY link above for other DIY's.
Old Jun 6, 2002
plastic's Avatar
plastic is an unknown quantity at this point
its kinda easy to replace rotors except the main bolts holding the caliper are kinda tight..need impact gun it out.. and also a torque screwdriver to take out those two lil screws holding the actual rotor up..besides that, easy install. [IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old Jun 6, 2002
2Hottie's Avatar
Impact gun? Damn! So I guess that it is easier for a pro to do it??
Old Jun 6, 2002
TEKNIQ's Avatar
Quote
2Hottie[hr]
Yeah, Grey has a great
D.I.Y.
Old Jun 6, 2002
TEKNIQ's Avatar
Quote
Impact gun? Damn! So I guess that it is easier for a pro to do it??[hr]
Get a little server lag????
Old Jun 6, 2002
Grey's Avatar
DIY King
Quote
[hr]Originally posted by: plastic
its kinda easy to replace rotors except the main bolts holding the caliper are kinda tight..need impact gun it out.. and also a torque screwdriver to take out those two lil screws holding the actual rotor up..besides that, easy install. [IMG]i/expressions/face-icon-small-cool.gif[/IMG][hr]
If you read my DIY it tells you what I did with those. The bolts that hold the caliper to the hub are torqued to about 80 foot pounds, but they easier to get loose once you spray them with WD-40 and turn your wheels to one side for easier access. The two little screws that hold the rotor to the hub were interesting. You need a #3 phillips head screwdriver bit to get them out. That bit bites in really well and you have enough of a grip to unscrew those suckers. Anti-siezing comound on the threads ensures easy removal next time around.
Old Jun 6, 2002
2Hottie's Avatar
I think that I will be using your DIY Grey, I already have it bookmarked....seems pretty easy!
2Hottie
Old Jun 7, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
ya, i need brakes!
SammySC
121
Apr 7, 2017 07:43 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Junquito89
Sep 27, 2015 10:22 PM
Bruce2
Sep 27, 2015 08:45 PM
Bikergofast
Sep 12, 2015 01:36 PM
