rear disk conversion
Old Jan 31, 2021
Shartbox's Avatar
Shartbox is an unknown quantity at this point
i'm looking to do a rear disc conversion on my 04 LX sedan, was wondering if i could swap the SI rear disk setup and if so, what parts are needed
thanks
Old Jan 31, 2021
Re: rear disk conversion
Short answer, yes. Rear knuckle assemblies (02's if you wanna retain the 4x100 lug pattern), rsx brake cables. If you can score a set of everything from an Acura 1.7el, you're golden, bc it's all the same chassis
https://www.civicforums.com/forums/4...elled-out.html
Old Jan 31, 2021
Shartbox's Avatar
thanks bud, was planning on getting mostly brand new stock components
Old Jan 31, 2021
I did the swap on my 02 coupe. It's a really straightforward swap. The RSX e-brake cables were a hair short, but if you open up the brackets and take up all and any slack, it'll reach
tfnaaf
30
Nov 24, 2005 08:45 AM
Rionmann3
Jun 20, 2004 05:02 PM
WhiteRiceBoi
Sep 25, 2002 08:27 AM
NoBottleJustThrottle
Jun 2, 2002 04:40 PM
artychris
Jan 8, 2002 01:33 PM
