Front rotor screws
Old May 24, 2018
misa098's Avatar
misa098 is an unknown quantity at this point
Front rotor screws
What up guys, so im replacing my front brakes on my 04 civic coupe. My left front rotor had stripped screws and i couldnt take them out with a #3 phillips. So i tried to drill into it and try to extract it. Unfortunately it didnt work, so i ended up drilling all the way through both the screws. I managed to knock the rotor off completely but there still some of the screw left inside the hole on the wheel hub. Can i use a tap set to rethread the hole? If so, what is the thread size. Thanks in advance. Hopefully i wasnt too confusing
Old May 24, 2018
Re: Front rotor screws
I, too, had to drill some rotor screws out and ended up drilling the threads out. Left them off, never had a problem
Old May 25, 2018
Leave the screws out.
Old May 25, 2018
piano55man's Avatar
piano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of light
The screws are only there for brake assembly at the plant. No need to worry about them.
Old May 25, 2018
many been there...
I was one of them recently...
https://www.civicforums.com/forums/1...ing-bolts.html
Old May 26, 2018
mikey1's Avatar
you will never get them out using a screwdriver
you need to use an impact driver
but like others said....leave them out, there is no need for them....your caliper and wheel nuts hold your rotor on anyway
