Need help w/ ball joint removal
Old May 6, 2016
trellex's Avatar
trellex is an unknown quantity at this point
I have been trying to get my wheel bearing replaced, and in doing so, I've hit a few road blocks, but for the most part, I pretty much have the process done, except for one thing:
I can't remove the crown nut on the balljoint bolt. When I try to loosen the nut, the bolt spins with the nut, and I just can't find a way to loosen it. Any one have any tips or tricks? Is there a special tool I could buy to get at this stupid nut undone? Do I just have to risk ruining the ball joint and replace that as well?
Thanks guys!
Old May 6, 2016
mac25's Avatar
Dr Krieger of Modification
Re: Need help w/ ball joint removal
You may have to use an angle grinder, cut the ball joint, then take it to a shop to press a new one in.
Old May 7, 2016
Speed9117's Avatar
Speed9117 will become famous soon enough
Have any friends with an impact driver?
Old May 7, 2016
mikey1's Avatar
Thanks guys!
if the ball joint is turning when trying to loosen that nut, in my opinion that ball joint is shot already and needs to be replaced anyway, so destroy it if thats what it takes to get the nut off, just dont damage the LCA or knuckle
Hrddrvs
19
Jan 4, 2017 09:36 AM
WaryDriver
Feb 25, 2016 05:18 PM
Tanner George
Feb 18, 2016 05:15 PM
06 EX Mild Mods
Engine DIY
Feb 17, 2016 05:52 PM
maxmccoy1969
Feb 16, 2016 07:23 PM
