just got wheels
just got wheels
aftermarket.. 15 inch.. can I use my tires off my stock rims and be ok? they are 195/65/15s... or I have a set of 195/60 15 ,, the new wheels have 195/50 on them now but I don't want them to look too small because im not lowering it for now... I have to drive it a lot and don't want the ride to be too rough...
any advice please? thanks
Re: just got wheels
The 195-60 would be a little shorter and the speedo reading would be off by a small percentage from actual speed.
The 195-50 are shorter yet, as you noticed. Even more speedo error.
Re: just got wheels
It should look the same as stock, just with a different look within the rubber.
The only analogy I can think of: Double stuffed regular oreos and double stuffed mint oreos look the same, just with a different cream filling.
edit: to tag onto ezone's comment, if you were to upgrade to larger diameter rims, you'd wanna get tires to match, or match as closely to, the stock overall diameter.For my car, stock was 185/65-15's, and my 17" rims are wrapped with 215/45-17's. It's as close a match as I could get, and my speedometer is only off by 0.2% due to the 0.15" overall diameter increase (0.47" increase in circumference), a negligible difference at best.
Re: just got wheels
Funny, you didn't mention this stuff.
About the time we say it'll be ok is when we will find out you are gonna try to stretch the tires onto some 12 inch wide wheels trynnabe hellaflush.
How much wider?
What's the offset?
How much different is it from the original?
Measure both and compare.
Bolt them on and see.
Keep all the tires in case you need them later.
How much wider?
What's the offset?
Re: just got wheels
Tire width will indirectly change the overall tire diameter. It's the whole 195/50 part. 195 is the treadwidth in mm, 50 denotes that the sidewall is 50% of the treadwidth. That said, if you go to something like 205/50, the sidewall will now be 5mm larger, giving the tire an overall diameter increase of 1cm
