abs brake conversion 01 dx
Old Jan 16, 2015
psychotropic28's Avatar
psychotropic28 will become famous soon enoughpsychotropic28 will become famous soon enough
Cool abs brake conversion 01 dx
hey everyone, on the way to work this morning an juuuuust missed T bone collision on wet roads tampa fl. i have a 02 ex with abs and an 01 dx without. had i been in my 02 it woulda been an easy stop. my girl usually drives the 01 dx, she would've wrecked my car.
soooo, how do i conv the 01 before i loose the car. i would consider it an investment to a car i've put alot of money into already so im more interested in the how rather than the if its worth it deal. nice EM2's are hard to find that someone hasn't ripped thru an altered the hell out of.
so far this is all i can find on the subject:
(You'll need to run a TON of brake lines, meaning bending pipe, flaring ends, etc. You'll need the ABS unit itself, the fuse box for it, new knuckles that have the mounting for the abs sensors, the sensors, new rear hubs and front axles with the ring gear for the sensor on them, and I'm sure more.)
anyone else have any insight. by the way i will eventually be doing the SI rear disc conversion on both cars anyways. bout a grand just to do that as it is.
Old Jan 18, 2015
Re: abs brake conversion 01 dx
no, nothin. guess theres a reason no one has tried it.. i love a challenge though.
Old Jan 19, 2015
first order of business. wiring. ive seen them on ebay but does anyone know where else to order the wiring loom for the car. that way i can order it with all the options i want like abs, cruise control, electric locks an windows, ect ect.
Old Jan 19, 2015
i can see from your thingie on the key programming that you are handy.
sorry, in your first post, i think you got everything required? don't have any additional items.
maybe yo could get away with zip-tying the ABS wires on the suspension - i do that on my mazda miata.
Old Jan 19, 2015
GolNat's Avatar
Prelude Owner
It's a big task!! Alot of money and effort that is not worth it to most people.
Good luck if you try.
Old Dec 22, 2015
Pier7866's Avatar
Pier7866 is an unknown quantity at this point
I would suggest to do rear disc brake conversion than ABS less headache than put drill and slotted rotors front and back your brakes will improve greatly as I did that to my 2001 civic. I changed nothing no master cylinder, brake booster or proportioning valve. But if you decide to do the ABS you will upgrade front brake calipers, hubs, rear drum hubs, plus you will also upgrade your ecu for it to work properly (which I am not sure). Hope this help.
Mad Dog Tannen
Sep 12, 2015 12:48 AM
thaler4cuse
Sep 7, 2015 08:25 PM
Pier7866
Sep 6, 2015 06:54 PM
cncnut
Aug 23, 2015 01:25 PM
honda.lioness
Aug 6, 2015 11:58 AM
