Stripped right bottom caliper bolt- still tightens
Old Aug 10, 2014
lx04le's Avatar
lx04le is an unknown quantity at this point
I'm replacing my brakes and I was wrenching on the bottom bolt for a few minutes and it still has play. The top torqued to 25 ft/lbs but the bottom keeps going. It's still really snug, so is this something to worry about, or as long as it's tight i'll be alright? Thanks for any help.
EDIT: the same thing happened on the left caliper. I can turn the bottom bolt under my own power with a short socket, but it takes a good amount of force. Both are on there tight. The top bolt on the left caliper wouldn't even come out but I just swung the caliper up and that wasn't a problem.
Old Aug 10, 2014
Re: Stripped right bottom caliper bolt- still tightens
If it won't tighten up then the threads are damaged on either the bolt or the hole it threads into, or both.
Heli-coil thread repair insert?
Old Aug 10, 2014
lx04le's Avatar
It's just weird to me that both front bottom bolts will tighten, but not all the way. I'll check into the inserts, I didn't even know those existed. Thanks for all the help I really appreciate it!
UltraHDGames
Jun 8, 2016 05:16 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
Junquito89
Sep 27, 2015 10:22 PM
jsmithe2010
Sep 25, 2015 07:42 PM
