Different Sized Tires in Civic 2004
Old Feb 15, 2014
nere's Avatar
nere is an unknown quantity at this point
Hi
I just bought a used Honda(my first) Civic 2004 coupe, value package edition.
Have been driving it for few weeks and am happy with my purchase.
But i noticed something yesterday:
The recommended tires for honda are : p185/70 R14. But on my car I am have p195/70 R 14.
My spare tire size is T115 70D14. My questions:
1. Will there be any issues because of different size.
2. Will there be any issues if I use the smaller spare tire with above tires.
Thanks
Old Feb 15, 2014
Re: Different Sized Tires in Civic 2004
Speedo will be off by a smidge.
2% according to a calculator.
50 MPH on the speedo will be 51 MPH.
Calculated mileage may be lowered by a similar amount.
Do you PLAN on driving on the spare for a long time? No more than 50 miles and no faster than 50 MPH.
It's for an emergency only, and no it won't hurt.
Old Feb 15, 2014
nere's Avatar
Thanks
No I dont intend to use spare tire as regular but wanted to know if I use it in case of flat tire.
When you say mileage you are referring to fuel efficiency or distance travelled.
Old Feb 15, 2014
By definition, the odometer is off by the same 2% as the speedometer.
When I typed the reply out, I meant calculated gas mileage, simply because of
1) odometer error and
2) taller tires alter the effective final gear ratios.
True gas mileage may or may not really change, if mileage is calculated using a GPS instead of the odometer for true miles traveled.
HTH
Old Feb 16, 2014
mikey1's Avatar
HTH
im a bit confused by your replys,
i dont think his tires are any taller than stock, they are just a bit wider, and in that case it would not affect the speedo or odometer at all, the overall diameter of the wheel/tire has not changed
Old Feb 16, 2014
They are taller in addition to wider.
1/2" increase in diameter.
Take your 2 tire sizes and go to any tire size calculator. I used this one:
http://tire-size-conversion.com/tire-size-calculator/
Plug the numbers in to the area labeled "Tire Size Comparison Calculator" near the bottom of the page, it will show you the difference in size.
It will also show you the differences in speed at various speeds (speedometer error).
If you want wider without taller, you have to go down in aspect ratio (the 70 would need to come down a step to 65). According to the calculator, that would be 0.2" shorter diameter than stock.
HTH
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
bo_red
Apr 23, 2015 10:09 PM
chgofirefighter
Apr 18, 2015 08:08 PM
tkcne
Apr 18, 2015 02:33 AM
GH04si
Apr 15, 2015 08:13 PM
