Rims match the computer
Old Aug 14, 2013
alex_nyc's Avatar
alex_nyc is an unknown quantity at this point
HI EVERYBODY, Hope your havng a great day!
I recently bought a 2003 civic ex with 14in rims(195/65/14 tires). As per the body sticker its supposed to have 15in rims (185/65/15 tires).
Is there a way I can check to see if the computer is set to 14in rims?
thanks in advance, alex
Old Aug 14, 2013
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
Re: Rims match the computer
Use a GPS while traveling at a steady speed and see if the speed on the gps matches the speedometer.
Old Aug 14, 2013
GolNat's Avatar
Prelude Owner
Can you change the computer to match your wheel size?
If no GPS your could have someone drive next to at a set speed and compare there speedometer to yours (if they have the proper wheel/ tire size for there vehicle).
Old Aug 14, 2013
alex_nyc's Avatar
YES you are all right. I can even look for those radar signs that post your speed.
I have to pick up an obdi scanner and was wondering where to look for rim size changes if they even have such a setting.
Old Aug 14, 2013
got2run5's Avatar
I don't think there's a setting like that.
Old Aug 14, 2013
No, there is nothing that can be reprogrammed for different rims on that car.
The ONLY thing that will keep your speedo accuracy intact is to match the tire circumference in revolutions per mile (or KM if metric) to the original spec tire size. Any variation from original contributes to speedo error.
This has absolutely nothing to do with wheel size or rim diameter.
I researched tire sizes and picked a set of tires that were an exact match to the original tires' overall diameter.
I went from 15 inch wheels with 195-65-15 tires to 18 inch wheels with 225-40-18 tires, the speedo accuracy is still golden because the OVERALL tire diameter is the same.
I used the tire calculator at miatanet to figure mine up. http://www.miata.net/garage/tirecalcold.html
Old Aug 14, 2013
alex_nyc's Avatar
The sticker on the car reads that i should have a 185 65 15 tire. Being that I have 14in alloys what 14in tire size would you recommend to match the size on the body sticker??
Old Aug 14, 2013
Sorry, can't do that at this moment.....
Use that tire calculator. Enter the correct size tire. Read the specs.
Play with the numbers to find a 14" tire that has the same overall diameter.
Parts catalog says 03 DX and LX cars got 185/70/14
EX got 185/65/15
UltraHDGames
Jun 8, 2016 05:16 PM
Bonobo
Oct 2, 2015 06:58 PM
skeener51
Oct 1, 2015 05:56 PM
Wariogamer
Sep 29, 2015 09:49 AM
260000milesgoal
Sep 25, 2015 07:41 PM
