front rotor bent?
Old Jul 13, 2011
floyd107's Avatar
floyd107 is on a distinguished road
front rotor bent?
not sure if rotors would go with tires and brakes correct me if im wrong. but if i had a bent/warped rotor that would throw my tire off rite.
Old Jul 13, 2011
sl33pyriceboi's Avatar
Re: front rotor bent?
wht do u mean "throw my tire off"
throw it off the rim? throw the balance off? throw.......?
Old Jul 13, 2011
lazlong's Avatar
Make it wiggle/vibrate when braking? Yes. Don't cheap out on the rotors or the same thing will happen again in a few months. You can cheap out on pads but, with worn rotors it will throw everything off.
If it's wiggling/vibrating when not braking it'll be a bad tire, unbalanced wheel, bad wheel bearing, or bad tie-rod. If it's any of the first 3 replace quickly but, it'll last a little while. If it's bad tie-rods replace IMMEDIATELY 'cause you can kill someone or yourself.
Also inspect the all the suspension components as several things could be worn.
Old Jul 14, 2011
floyd107's Avatar
well thats the thing my tire dosent wiggle at all i just hear a constant noise kinda like my rim is bent but i hear it even with it off. i feel it in my pedals too. so idk if its my bearings or what.what size is that big bolt on the rotor so i can get a socket to remove it. (oh yea by throwing off i mean wiggle, etc)
Old Jul 14, 2011
lazlong's Avatar
Don't quote me but, I think it's 36mm.
Old Jul 14, 2011
floyd107's Avatar
ok thanks ill try it out i will let you now what i see ohh and one more thing my driver side tire at the top is leaning inward like i have a camber kit. is there a way to adjust that.my front end is all stock so i dont know if i can.
Old Jul 14, 2011
lazlong's Avatar
you need camber bolts
Old Jul 14, 2011
floyd107's Avatar
but is it supposed to be inward like that being that i dont have the bolts. what would make the stock front end to do that.
Old Jul 14, 2011
lazlong's Avatar
Bad struts and/or springs. You're looking at about $1000 for both sides to repair at a shop (you always replace suspension components in pairs or you end up with even more problems). $300-500 if you do it yourself. Camber bolts are like $10-20.
Old Jul 16, 2011
floyd107's Avatar
is there a way to kinda tell if it is my spings and struts before i go off and buy new stuff.i dont want to be deep in the pockets with the same problem.
Old Jul 17, 2011
lazlong's Avatar
Push that end of the car down. It should go down, come up, then stabalize. Any more than that and you need new struts at least. You can't check the springs unless you take them off the struts.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Misfit2613
Brakes
26
Sep 1, 2018 05:02 PM
bsmiley
Apr 27, 2015 01:27 PM
chgofirefighter
Apr 18, 2015 08:08 PM
tattedlariat
Apr 12, 2015 07:55 PM
