remove rust from front discs and rear drums?
Old Jan 27, 2011
jeffconnell12's Avatar
jeffconnell12 is an unknown quantity at this point
hey guys ive just purchased new wheels and now see the large amount of rust on the front discs and rear drums how can i remove these and clean then paint them with caliper paint..im a nooby to brakes thankes
Old Jan 27, 2011
Mad Dog Tannen's Avatar
Re: remove rust from front discs and rear drums?
Yes you can. Just make sure that you don't sand or wire brush where the pads/shoes touch and you will be fine. And use brakleen on the surface after handling them. mAke sure to get all the rust off before you paint and mask the contact surface.
Old Jan 27, 2011
MindBomber's Avatar
Live for the Twisties
Sand them with sand paper, clean them off with brake cleaner, mask the area off and give a few light coats of paint. Done.
Old Jan 27, 2011
BobDobolina's Avatar
TRUST me! I'm Idiot Proof!
BobDobolina has a spectacular aura aboutBobDobolina has a spectacular aura aboutBobDobolina has a spectacular aura about
As if the last posts weren't enough, check out this guys DIY
Old Jan 27, 2011
1. rust dissolver gel and wire brush
2. rinse with water
3. spray brake parts cleaner
4. caliper paint
Old Jan 29, 2011
mac25's Avatar
Dr Krieger of Modification
lol you guys forgot primer.
you can not use primer but the problem with out it the paint can run with the next layer because something in the spray paint acts as a solvent and makes the "dry paint below run. i had this problem because i didn't use primer when i ran out so i had to wait 20min between spraying rather then the usual 10min and had to use like 5 layers where i usually need two with a third just to make sure it's all covered.
Old Jan 29, 2011
ive never had issues spraying on a few coats of caliper paint. going on two years but i will be repainting next year due to some chips and misc wear and tear. the paint dried fast tho, i would say maybe 5 mins.
Old Jan 29, 2011
mac25's Avatar
it's wet here, but i didn't want to wait for hot weather when i did mine.
Old Jan 29, 2011
MindBomber's Avatar
Understatement of the century haha.
Our climate has a huge impact on curing time of any reaction, whether it be concrete, paint or anything else..
Old Jan 29, 2011
yeah i remember those days. painting in 100% humidity isnt fun
Old Jan 30, 2011
mac25's Avatar
bahh ha ha ya, we should rename vancouver rainyville, lol. maybe then we'd ironically have sun.
rtachs
Jul 16, 2015 05:32 PM
Optimus34
May 25, 2015 11:52 PM
vtec_concept
May 24, 2015 10:27 AM
rhvic
May 22, 2015 03:06 PM
Broadbeb
May 14, 2015 09:49 PM
