Question about bleeding brakes
Old Jul 13, 2010
grendel's Avatar
grendel has a spectacular aura aboutgrendel has a spectacular aura about
Question Question about bleeding brakes
Hey folks...
Gonna be working my way through bleeding my brakes soon (DIY-style) for the first time.
Wondering how much brake fluid I'm going to need to buy?
I'll be doing all 4 corners...
TIA!
Old Jul 13, 2010
Re: Question about bleeding brakes
usually one small bottle. use the honda stuff, maybe get two bottles in case you mess up or spill.
Old Jul 13, 2010
grendel's Avatar
thx gearbox!
Old Jul 13, 2010
02civicsi02's Avatar
Low and slow!
I would say get 2 bottles from honda just in case.
Old Jul 14, 2010
sl33pyriceboi's Avatar
if u are planning to BLEED and flush ur system (try to get all new fluid in ur lines and system.....which is highly recommended) you should buy at LEAST 2 bottles (a total of 1liter)
i used almost a full liter when i flushed my system.
and by "flush" i mean bleed ur brakes until only clean fluid come out. and then rebleed them jsut to make sure all the air is out.
Old Jul 14, 2010
grendel's Avatar
Yeah, this is the plan - all the old out, and all new in.
I'll buy bulk, just in case.. lol
Thanks folks!
Old Jul 14, 2010
Kennykid2002's Avatar
Kenny the Ricer
I buy the large yellow prestone dot 3 32oz
Works great and its only like 5 bucks
It doesnt really take a lot of fluid if you're just bleeding it, maybe like 10oz if you're flushing, though
Old Jul 15, 2010
try and get a DOT4 rated fluid. it has a higher wet/dry boiling point.
just as long as u dont use DOT 5 then ur ok.
Old Jul 15, 2010
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
Just a heads up. Most brake fluid is hard on paint and will remove paint if left long enough. Just be careful when you fill the master cylinder and rinse with water if you get brake fluid on a painted surface.
Old Jul 15, 2010
grendel's Avatar
Will do, for sure... I'm uber paranoid about **** like that.. lol
Old Jul 17, 2010
combinatorix's Avatar
combinatorix has a spectacular aura aboutcombinatorix has a spectacular aura aboutcombinatorix has a spectacular aura about
Don't bother buying the 32 oz. bottles. You don't need too much, and it doesn't stay good once it's unsealed. After a bottle has been opened, it slowly absorbs water and loses its boiling point.
You can get the ~12oz bottles, you shouldn't need more than two. Unless you are planning on racing or something, DOT 3 or DOT 4 should work fine. For long-lasting use, the wet boiling point is most important, and it can vary wildly by manufacturer even if you're getting DOT 4. Don't get DOT 5, it's silicone based and generally inferior performance-wise, and is sometimes not even compatible with master cylinder seals.
Old Jul 17, 2010
most of them will come in 500ml. brake fluid is not that expensive. if u have an extra couple of oz on ur bottle its not gonna hurt.
i bought my valvoline bottle (1L) for about 10 bucks.
if u want to get real good brake fluid, id suggest motul RBF600 or better, the RBF660. but those are about 20 and 30 bucks a bottle of 500ml
Old Jul 17, 2010
grendel's Avatar
Yeah, no DOT5 for me.. lol. I picked up some DOT3 Honda fluid... figure that should be good enough
I'm definitely not that baller... heard good stuff about Motul, though - maybe one of these days....
Old Jul 17, 2010
its not really necessary on a street-driven car. but if u used ur car for the track, its well worth the money.
i use the rbf600 on my bike tho.
Old Jul 19, 2010
grendel's Avatar
Mission accomplished... much smoother than I anticipated.
My buddy and I worked our way through replacing pads/rotors on all four corners, and bleeding the fluid.... 3 hours. That included beer and pizza breaks
Thanks for the replies all!
Old Jul 19, 2010
Low and slow!
Beer is always a good thing to have while working on cars. Glad you got it done.
Old Jul 20, 2010
MelJ's Avatar
Trance Addict
You might wanna exchange "while" with "after" . Lol. Good to hear ya got it done. Saved yourself some serious moola doing it, and a great learning experience.
Old Jul 20, 2010
Kenny the Ricer
Kudos to that
Old Jul 20, 2010
Low and slow!
Lol na I got it right. I am not talking bout getting drunk but 6 pack will do.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
masongap
May 26, 2015 07:55 PM
bsmiley
Apr 27, 2015 01:27 PM
viper775
Dec 9, 2001 10:52 PM
