Brake Fluid change...
whats the best way to change my brake fluid at home? the only thing im not sure how to do is drain the fluid. i can bleed em and everything but how should i drain all the fluid out?
Re: Brake Fluid change...
u pretty much need two people to do it properly.
one person pumping and the other person opening/closing the bleeder valve...
then put some more fluid in (make sure the reservoir doesnt run dry) and keep bleeding untill u see clean new fluid.
do that for every wheel in this order: front driver, front passenger, rear passenger, rear driver.
u can also look at buying some speed bleeder valves (replace ur stock bleeder valves) and that will make ur car's bleeding job turn into a 1 man 5 min bleeding job (yes 5mins for all 4 wheels)
Jul 12, 2015 11:54 AM
OptimisticWay
Jul 10, 2015 04:31 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
Causemo
Jul 5, 2015 06:42 AM
