16" or 17" rims on a Civic 02 LX without lowering?
Old 06-30-2009
danzz1234's Avatar
danzz1234 is an unknown quantity at this point
Anyone have pics of Civic sedans with 16"/17" rims without lowering?
I'm thinking of buying new rims, but I don't want to low it right now, just want to make sure it won't look THAT bad
Thanks!
Old 06-30-2009
kcari's Avatar
Re: 16" or 17" rims on a Civic 02 LX without lowering?
yes. 16s will give you more gap. 17s will raise your car a little bit, but depending on tire size you'll have less gap. i recommend 215 45 17 if u want a thicker tire that shouldnt rub if u decide to lower an inch or 2 in the future. goodluck
The following users liked this post:
StepKuyaMark (12-24-2021)
Old 06-30-2009
lowlife9's Avatar
17's if you like the monster truck look.
Old 06-30-2009
kcari's Avatar
^ huh? 16s are going to give you more gap if you arent lowered.
isnt that ultimately what you want to avoid?
Old 06-30-2009
unTuned's Avatar
well youre both partially right. lets consider that you have the exact same size rubber on a 16 and a 17.
the set of 16s will make your entire car sit 0.5" lower to the ground, but will make your wheel gap 0.5" bigger.
the 17 will make your car sit 0.5" higher off the ground than the 16 but will make the wheel gap 0.5" smaller.
you have to remember the radius of the rim is half an inch bigger on the 17s, so it basically 'pushes' the tire size outward which fills the wheel gap.
Old 06-30-2009
danzz1234's Avatar
So, basically, 17" all the way?
I guess I'm staying with the 15" lol
I read that 205/50/15 would look good without lowering (of course its a different thing), what do you guys think?
Old 06-30-2009
kcari's Avatar
its up to u and what you want. do you want less wheel gap or do u want to sit lower to the ground?
Old 06-30-2009
+MM+'s Avatar
+MM+ will become famous soon enough
If you're not lowering, 17s for sure. And just like kcari said, 215/45/17. I have that exact size and I'm happy. If and when you will be lowering, I wouldn't go too low or you will rub on the plastic shrouding on the insides of the front fenders, and you will also need to roll your rear fenders.
Old 06-30-2009
kcari's Avatar
with a proper rear camber kit and about -1.5 degrees of camber in the rear and about -1 in the front you wont need to roll your fenders unless u got fat friends.
Old 06-30-2009
+MM+'s Avatar
True, but I do a lot of driving and would like my tires to last me at least two summers.
Old 06-30-2009
unTuned's Avatar
if you are worried about gap size the 205 50 r15 would make you cry. the wheel well gap would be almost an inch and a half BIGGER than the stock gap.
i also have 215 45 r17 and i am very happy with it. the overall diameter of the entire tire is only a couple mm off of stock size so it keeps your car at the same height and keeps your wheel well gap just a bit smaller. thats what you should do. if you are going to use r15s, do not change the rubber size unless you are going to do a suspension drop.
Old 06-30-2009
dillinger's Avatar
dillinger is an unknown quantity at this point
My 05 sat like a truck with 15 inch rims at stock height and i have the factory lip kit, it looked like you could roll under the car...
imo spend the money on suspension before wheels you will be happier in the end.
i dropped 1.5 inches and its perfect no scraping and about a 2 finger gap.
Old 06-30-2009
kcari's Avatar
-1.5 camber is still within oem spec and will last. toe is what eats tires, not camber. I've been rolling around with -2.0 camber in my rears for almost 2 years and my tires dont have any camber wear
Old 07-01-2009
back2black's Avatar
back2black is an unknown quantity at this point
Camber will wear tires out, and fast, if it is too far off.
ROb
Old 07-01-2009
Pistol grip pump in my lap at all times
mr22508's Avatar
mr22508 is a jewel in the roughmr22508 is a jewel in the roughmr22508 is a jewel in the rough
This was my 02 ex on 17" ADR's...I thought they looked good.
Old 07-01-2009
darkhonda2k2's Avatar
darkhonda2k2 is an unknown quantity at this point
with the proper tire size, you wont change the wheel gap at all.. the perception of the gap can change with different styles of wheels.. like big lips look like theres more gap...
http://www.miata.net/garage/tirecalc.html
Old 07-01-2009
EnvyX's Avatar
EnvyX will become famous soon enough
finally someone that knows his ****. It wont adjust any heights, but the smaller tire on the 17 will give the illusion that theres more wheel gap.
Old 07-01-2009
unTuned's Avatar
everyone is confusing the poor guy. all he asked was if it would look fine. he obviously isnt going to lower it, thats what he asked in the first place.
its really simple. if you do NOT want to lower your vehicle or change your suspension, you have to sacrifice the overall height of your car and make it ride a bit higher (by getting bigger rubber) to make the wheel well gap smaller
OR you have to sacrifice your wheel well gap and make it even bigger (by getting smaller rubber) in order to have your car height ride a little bit lower.
the entire diameter, of a 17 inch rim with 215/45 rubber is as close as you are going to get to the diameter of a stock 15 inch rim with a stock 185/65 rubber.
Old 07-01-2009
danzz1234's Avatar
Thats what I would like to know. Thanks.
And it seems that with 215/45/17 I could low it a little without problems, right?
What tire size is this?
Thanks all.
Old 07-01-2009
unTuned's Avatar
that is correct. if you go with 215/45/17 you will be able to drop up to about 1.5 inches without having any problems. once you hit around the 1.75 to 2 inch drop, you may have to roll your fenders.
ill go take a picture of my car with STOCK suspension, with 215/45/r17 so you can see how mine looks.
Old 07-01-2009
unTuned's Avatar
this is stock suspension with 17" with 215/45/r17 rubber. wheel gap and car height is literally exactly the same.
ID:	76805   Click image for larger version
Old 07-01-2009
mr22508's Avatar
Thanks all.
215/45/r17's, on a stock suspension. And I have since then dropped my ride 1.75 inches and it rides fine! I hit some pretty big dips doing about 80 and never even rub. Check it...
Old 07-01-2009
danzz1234's Avatar
Wow, thank you guys!
I might just go 215/45/17 (wich doesn't look THAT bad) and low it in the future!
Now I'm working in my headlights, clearing them, then instaling HID etc.
This forum is awsome, thanks all!
Old 07-02-2009
unTuned's Avatar
no problem. if you need more help just ask.
as people help you out though, make sure you are giving rep out. underneath their name there is a little scale looking type thing. click on that and it gives rep to people helping you.
Old 07-02-2009
dubD02CiViC's Avatar
dubD02CiViC is an unknown quantity at this point
02 LX Sedan on 17's stock height.
Old 07-02-2009
thenewdiabolic's Avatar
thenewdiabolic is an unknown quantity at this point
215/45/r17 FTMFW
Old 07-02-2009
danzz1234's Avatar
I've added reputation to almost everyone in this topic!!
If anyone has any other "useful" pic, post it please!
But 215/45/17 doesn't look bad at all!
thenewdiabolic: awsome car I don't like the black rims much, but thats looking good. Thanks for posting pictures
Old 07-02-2009
danzz1234's Avatar
Old 07-06-2009
02_civiclx's Avatar
02_civiclx is an unknown quantity at this point
My 02's ride height looks exactly like yours. I'm waiting to fund for tein - s or eibach springs.
Old 07-06-2009
cleanlikejdm's Avatar
cleanlikejdm is an unknown quantity at this point
just do a decent drop and rock 16s and it will look nice
Quick Reply: 16" or 17" rims on a Civic 02 LX without lowering?
