pads for drilled & slotted rotors???
ok i have Brembo drilled & slotted rotors on the front no there not bigger than stock, there stock size!! well my question is what kind of pads would be good for them? should i use ceramic pads? cuz everyone iv talked to said to NOT use ceramic cuz the pad is to hard!!! and i have the pads that they sent with the rotors on there right now but its about that time to change them. so what kind of pads??????
Re: pads for drilled & slotted rotors???
If it's time to change the pads, then it's also time to change the rotors, or at least get them re-surfaced.
I use PBR Metalmaster pads, they are the same as Axxis pads. Semi-metallic, low dust and grip like mad.
Junquito89
Sep 27, 2015 10:22 PM
Bruce2
Sep 27, 2015 08:45 PM
