185/65/15 or 195/60/15?
Old Nov 25, 2007
choughster's Avatar
choughster is an unknown quantity at this point
hey guys,
i plan on getting tokico blues & tein h techs on my 03 ex coupe.
for tires i plan on getting falken ziex 912's...so, right now i'm debating on these two tire sizes. should i stay w/the stock 185's or upgrade to the 195's? will it affect the performance at all or does it matter?
thanks in advance!
Old Nov 25, 2007
phuviano's Avatar
Slowest 7thgen in the GTA
Re: 185/65/15 or 195/60/15?
Wider is always better, performance wise, except in snow.
Old Nov 25, 2007
choughster's Avatar
i live in cali so i don't have to worry about snow
so, the 195's are the way to go?
Old Nov 25, 2007
phuviano's Avatar
Yup.
I'd even go with 205/55/15.
185/65/15 will give you the better ride quality, but 205/55/15 will perform better. 185/65/15 is for granny's.
Old Nov 25, 2007
choughster's Avatar
granny...lol!
i thought about the 205's but w/the h techs won't that be more of a wheel gap?
Old Nov 25, 2007
phuviano's Avatar
Originally Posted by choughster
granny...lol!
no, all sizes mentioned so far will leave around the same gap.
Old Nov 25, 2007
choughster's Avatar
how about 205/60/15?
they don't have a 205/55 but have a 205/50...
Old Nov 25, 2007
greeen01civic4d's Avatar
id do 205/50, not 60, 60 has a bigger sidewall and will make for a bigger gap
Old Nov 25, 2007
and here u go for the 205/55/15
http://www.tirerack.com/tires/Compar...=7&RunFlat=All
Old Nov 25, 2007
d5685090's Avatar
d5685090 is an unknown quantity at this point
those 50s are too small. ur car will look weird, mine did. the sidewall size only affects ur car very minimal, cuz the smaller wheel will spin a whole 360 slightly faster than the bigger one, meaning that the torque increases but not that noticeable. if they have 205/60or65/15 that would be best. more traction is better. u dont wanna end up in a ditch or flying of a cliff at 50 on a hairpin turn lol. thats my opinion.
Old Nov 25, 2007
d5685090's Avatar
and remember that even thou the sidewall is bigger the tire has more grab cuz more rubber is touching the road
Old Nov 25, 2007
d5685090's Avatar
u can always adjust the ride height
Old Nov 25, 2007
choughster's Avatar
yeah, thats what i figured...also, keep in mind that these are going on 15's.
Old Nov 25, 2007
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
you're talking a cm in sidewall height with the tires you've mentioned. not all that noticeable. my 04 ex came with 195/65s on the stockers and i just put a new set on them... i might ride them for a while, tired of the harsh ride on 205/40R17s....and i have blues and s-tech springs. bout a 1/2 inch gap rear and a inch or so up front. but my rear sags a bit....
Old Nov 25, 2007
sl33pyriceboi's Avatar
get 205/55/15
don't listen to anyone else that says anything else...
as for me, I'm running 215/t50/16. which gets me closest to stock... but I kinda regret it cuz they look kinda fat (im use to rinning low pro. I ran 205/45/16previously)
Old Nov 25, 2007
choughster's Avatar
so...205/60/15 or 205/55/15?
i don't care if they look too fat or not cause the h techs only give an inch drop so anything too "low" will cause more of a gap?
Old Nov 25, 2007
d5685090's Avatar
ill just turn my head the other way if i ever see you on the streets with those 55s.
Old Nov 25, 2007
choughster's Avatar
so, 205/60/15 it is
Old Nov 25, 2007
d5685090's Avatar
good choice. :wink
Old Nov 26, 2007
amuthini's Avatar
amuthini is an unknown quantity at this point
for sure you don't want 205/50.... the gap will be at least 4 fingers with h techs. so i vote 205/55
Old Nov 26, 2007
choughster's Avatar
so, wouldn't the 205/60/15 close the wheel gap more than the 205/55/15?
Old Nov 26, 2007
d5685090's Avatar
yes the bigger sidewall will close the gap. and the ride is less rough. 55s look weird on 15s.
Old Nov 26, 2007
Spikez1222's Avatar
Spikez1222 is an unknown quantity at this point
205/60/15 all the way...
Old Nov 26, 2007
itll change ur speed some, not much, but a little, check alpha5's signature for a link to the tire calculator
Old Nov 26, 2007
choughster's Avatar
sweet thanks for the input guys...it looks like i'm gonna go w/the 205/60/15's.
one last question will 205/65/15's look too big?
Old Nov 26, 2007
amuthini's Avatar
205/55 is the best compromise between getting a nice sidewall height and closing the gap.... if you get 205/60 your sidewall will be huge even bigger than if you had just stuck with 185/65. its not gonna be a pretty site your wheels will look tiny in those tires, although you'll have no gap.
Old Nov 26, 2007
choughster's Avatar
hmmm...you're not making this easy for me
have any of you guys seen 205/60/15 or 205/55/15's?
on tein h techs?
Old Nov 26, 2007
d5685090's Avatar
trust me you will regret going on 55s i did. those 55s would look great if u had 16s or 17s but not stock.
Old Nov 26, 2007
LoneWolf's Avatar
LoneWolf is an unknown quantity at this point
hmmm well I had 50s on my SI rims. they rode great. a bigger tire wouldve made my rims look small
Old Nov 26, 2007
CenZ's Avatar
PWIT
i have those exact tires on my winter tires. i got 205/60/15 i got 2" drop and now gap.
