Bridgestone Blizzak WS-60
So, I need new tires for my car and considering it is now the middle of November, I think it would be best if I went with a winter tire.
I do a lot of driving on I-95 between NJ and VA, and I know how bad it can get when it snows.
Anyone use these in snow/ice and dry and wet conditions? I'll be putting the stock size on, 185-65/15.
Re: Bridgestone Blizzak WS-60
Before you purchase these tires, given the way in which you intend to use them, check with a reputable source such as the Tire Rack or Discount Tire Direct to see the advisability of running them at relatively high sustained speeds, as well as what you can expect for tread wear life. You may find that they don't meet your needs or intended use.
i was still able to drive okay in 1ft+ of snow on the ground with all seasons last year without crashing.
