Brake problem- Torn caliper boot
Old Aug 1, 2007
aks0322's Avatar
aks0322 is an unknown quantity at this point
i was having problem with my brakes and it turns out in addition to warped rotors, botts on the caliper are torn..he suggested I should replace and calipers with new ones...and will cost me around $300+.....How difficult it is to replace calipers myself...is there a DIY.....I searched everywhere but didn't find DIY for calipers...Also...how to flush the hydraulic system...I was told i need to do that....Is it same as changing Brake fluid? I am thinking of buying cailpers myself and replacing it...any suggestions/tips would be helpful...do I need any special tools?
thanks
Old Aug 1, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Re: Brake problem- Torn caliper boot
Civic calipers have gotta be about 35 bucks each at autozone after you return the cores. If you have a buddy, you can bleed brakes. The DIY is on here somewhere.
Old Aug 1, 2007
AmbulanceMonkee's Avatar
shouldn't be that hard, and yeah, bleeding them is about the same as changing fluid, assuming you've been doing that the right way. hell, while you're at it, upgrade to steel lines.
Old Aug 2, 2007
aks0322's Avatar
Thanks guys..i will search for method to bleed the brake lines....
Boilermaker...what do you mean by return the core? do you mean return the bad calipers?
Thanks
Old Aug 3, 2007
yeah, you return the old ones, and they use parts of them to make new ones. you get money back for bringing them back.
JohnnyBxo
Nov 12, 2015 03:04 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
drhawkinz
Suspension
21
Aug 18, 2015 01:38 PM
exiled1
Aug 8, 2015 06:09 PM
DerbyDad03
Jul 27, 2015 11:34 AM
