Something Grooving my Discs
Old May 13, 2007
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
I got my rear drums swapped to disc and the other day I went out to test the brakes out. After several 60-10 and 80-20 stops my brakes were smoking. Today I noticed the front right discs has two grooves going all the way around. I know discs should be flat, so this is bad.
My question is what could have caused this grooving to occur? I'm going to change that disc and install new pads. But I don't want it to happen again.
Old May 13, 2007
Re: Something Grooving my Discs
maybe some debris or rocks got stuck inside?
Old May 13, 2007
TRIZ's Avatar
The groves are on your orig front discs correct- if so, could be caused from running your breaks down beyond their useful life, or debris as gear said. Two small groves arent going to hurt performance to any noticeable degree. I've seen rotors that are much older and they were completly groved- thats what you want to avoid. For the most part, if you change your break pads regularly, your still going to end up with some small groves on your rotors. Run your fingernail across the surface, if you have a lot of groves that are close to gether, replace them.
OLD (needs to be replaced) VS NEW rotor.
Old May 14, 2007
BlueRevs's Avatar
BlueRevs is an unknown quantity at this point
yep, sounds like your rotors are gone. You'll proly want new pads too because the rotor proly ruined those too
Old May 14, 2007
2k1civic01's Avatar
2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice
the rotor on the left looks like my **** right now LOL
hatch90
Sep 3, 2015 08:45 AM
naokigoffi
Aug 30, 2015 06:19 PM
WaryDriver
Aug 16, 2015 11:22 AM
OptimisticWay
Jul 10, 2015 04:31 PM
