Brakes Scratching Sound
Old Sep 22, 2006
evi's Avatar
evi
evi is an unknown quantity at this point
Can anyone help me with my brakes. Whenever i drive from a parking there is this scratching sound on my front brakes that only sounds for a few seconds and then disappears. I have brought it in for servicing several times and the mechanic told me that its a normal for ABs to have its Self Test whenever you drive your car. Is this right? Cause this is also my first car with ABS and i have not encountered this with my old car. Hope you could shed light on this issue i've got. TY.
Old Sep 22, 2006
Da1lyDr1ver's Avatar
its not "self testing". i actually dont think any cars do that...
i'm pretty sure its your brake pads rubbing off the corrosion/rust from the rotors. the surface of rotors corrode very easily so thats common for you to hear a scraping sound the first time you step on your brakes after parking it.
Old Sep 22, 2006
fatal Error's Avatar
fatal Error is an unknown quantity at this point
i get the same thing all the time....I've takin it all apart twice and the only thing I find that makes logical sense is brake dust griding with the pad..
Old Sep 22, 2006
susuking's Avatar
susuking is on a distinguished road
or the brake pad is made of "cheap" material. use some known brand, and u'll notice it goes away
Old Sep 22, 2006
Rennen's Avatar
New Mod on the Block
i noticed that too. i used to have a screeching problem with my brakes too. then i changed them to Hawk pads and now they're completely silent.
Old Sep 22, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Brake wear indicators
cold brake pads (some compounds will be noisy until hot)
rotor surface corrosion
I'm sure I could think of more the longer I sat here, but those are the 3 highly likely ones.
ABS doesn't self test by activating itself. Find a new mechanic.
Old Sep 22, 2006
admit1's Avatar
admit1 has a spectacular aura aboutadmit1 has a spectacular aura aboutadmit1 has a spectacular aura about
maybe the calipers are sticking slightly when cold.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
TiggerDX
Jun 18, 2015 01:43 PM
MamaBear2015
Jun 11, 2015 07:33 PM
masongap
May 26, 2015 07:55 PM
