tire size
Old Sep 10, 2006
Dominiksi's Avatar
Dominiksi is an unknown quantity at this point
tire size
Dose anybody know if a 205/50/15 tire will fit on a stock 04 ex rim
Old Sep 10, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
Yes. It will fit.
Old Sep 10, 2006
Dominiksi's Avatar
thanx
Old Sep 10, 2006
EMTwannabe's Avatar
EMTwannabe is an unknown quantity at this point
Should be 205/55R15
Old Sep 11, 2006
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
205/50/15 will look funny if you dont have a drop. with a drop it looks good.
Old Sep 19, 2006
rcelefano's Avatar
rcelefano is an unknown quantity at this point
I just bought those size of tires. they look good on their own since its almost low profile, but that gap is way to big between the tires and the car now. So its practically a must to lower your car with those dimensions.
also, your car now has to rev higher to get normal speed with bigger tires.
at 100km/h i use to be at 3,000 rpms. now im at 3200 rpms. it gets worse the higher speed you go.
you should do some calculations with tire sizes.
normal size is 185/65, which means the size of the wall will be 185*.65=120.25mm
(205/50) 205*.5=102.5mm
.: 120.25-102.5mm = 17.75mm smaller
so mess around with calculations like that, and you'll be able to figure out the gap between your car and the tires. I got too greedy
does anyone know if we can put 215 on our stock 15" rims?
Old Sep 19, 2006
dopes6070's Avatar
just drop it like 1" and it will look clean
Theshwartz35
Jul 17, 2015 11:13 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
muttleytm
Jul 8, 2015 04:13 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
