205/50-17
Old May 31, 2006
smalie25's Avatar
New Member
smalie25 is an unknown quantity at this point
Question 205/50-17
Should I put 205/50-17 on a 17-inch Grams Light T57-RC ??
Old May 31, 2006
pon55's Avatar
No....
Old May 31, 2006
smalie25's Avatar
New Member
Other than 3.57% too slow what other reason for NO.......
Old May 31, 2006
pon55's Avatar
If you have 40 series 17s they are slow and put the weight far from the center,but liveable.
the 50 series are taller for higher gearing, more power cumsumption (heavier and further from center), and they will probably rub with any drop.
Old May 31, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
What's the point? Unless your only reason for wanting them is road noise, You should have gotten some 16's. A 50 series sidewall will look retardedly high. I have 45 series and I think they're way too thick. And like Pon said, if you're dropped at all, they WILL rub
Old May 31, 2006
smalie25's Avatar
New Member
Just searching for best option! I'm ready to buy wheels and its between 17-inch Grams Light T57-RC or 16-inch WedsSport SA90
Old May 31, 2006
The best option for minimal road noise, minimal speedometer distortion 215/45
Best for looks is 205/40R17
Best compromises are 205/45 or 215/40
Old May 31, 2006
diskreet's Avatar
The less unsprung weight the better!
Old May 31, 2006
smalie25's Avatar
New Member
With new 17-inch all that has to be done is Aligment and balancing
Old May 31, 2006
pon55's Avatar
You post was tire size, not rim size??? Put 205-40-17 on them if you can get around the pot holes!
Old May 31, 2006
smalie25's Avatar
New Member
I little of everything Thank for the tip !!
SevenCyrus
15
Jan 3, 2005 11:26 PM
