215/40/18 or 225/40/18
Rep Power: 310 here's 225/40/18 + 40 offset 7.5" rims + Prokit + rear camber kit on mine
steering wheel turns still full either way.
wheels do not stick out farther than the fenders.
only scraped on the fender lip when there was a dip on the highway, at 45+ mph
they fill up the gap really nicely. have fun
How many pots have you smoken?
Rep Power: 272 215/40/18. its a tight fit haha.
^ you mean most people run 205/40/18s? or 35s? i just did a quick search and only found 2 tires that make that size and they're $200 and $260 each!
Rep Power: 272 me? well i can tell you this. when im driving normall its fine. maybe a little bouncy in the turns, but thats it. when im driving...shall we say more spirited...i can hear either 1 of 2 things (im not sure whats actually causing the noise) its either the shock compressing all the way - "bottoming out." or its the tire scraping the inner fender wall as the body leans. the sound comes from the front, outside corner. (if i make a fast right hand turn, the driver side scrapes, fast left hand turn the passenger side scrapes.)
at first i thought it was the shock - but then i listened more carefully and it sounds exactly as it did when i first dropped my car and the rears were rubbing because i didn't have a camber kit on. im not sure. either way - ive been thinking heavily about getting Eibach Prokit springs.
Rep Power: 272 http://www.7thgencivic.com/forums/sh...3&postcount=70
that was about last summer i believe. the rear is tucking now though. honestly - that red vic some1 posted above looks hot! and you wont have to worry about the problems that come with a lowered car as much. i think i made up my mind after seeing that ^ vic that im going to go with the prokit
Rep Power: 270 ^^ im running 215/40/18 with my fn01rcs......(5zigen) and i was dropped on tokicos and tein s.techs....wit hclose to a 1.5 all around. now im on d2 full coilovers like about 2.25 all around and i dont rub at all!! im thinking about getting 225s and rolling my fenders.....so yea...need pics? lemme know
Originally Posted by civic_newbie
Mr_Fobster what offset do u have, and how are the D2 coilovers? I was thinking about getting them but can't find many reviews.
i have a +43 offset
with the d2s man...they handle like a CHAMP!! waiting for my front and rear progress sway bars....and then my body roll will be reduced significantly.
with just the d2s alone my car is stiff...these arent meant for daily driving....but it has made my car very stiff......if i stand on the rad support in the engine bay of my car and try to jounce the car it practically doesnt do anything....maybe alittle bounce....but i have to say again, the car with this suspension(d2 full coilovers with upper camber plates and pillowball mounts) makes the car pretty stiff.
i still need to play around with the dampening settings so yea......
but i am planning to do 225s with my current setup...just need to roll the fenders for it to work.
bluestreak
04-18-2003 03:20 PM
