Brake problem?
Old Apr 28, 2006
hexed's Avatar
The black russian
hexed is an unknown quantity at this point
Brake problem?
Need help guys
Today I was painting calipers. I noticed that when i was tightening the front driver side wheel it was spinning, while someone was pressing brakes.
The passenger side, on the other hand, was very tight when brakes were pressed.
I hope its just the pads, but probobly not. What else should i look for?
Thx.
Old Apr 28, 2006
Honda_Inspired's Avatar
Honda_Inspired is an unknown quantity at this point
Are the pads squealing when you drive? If not, your pads are fine. I would check to see if your driver side piston is engaging. If it doesn't engage, try bleeding the brakes.
Old Apr 28, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Check the right rear (same channel) compare to right rear. Try bleeding the lines, also check for a pinched line if you had the caliper off and didn't hang it, or were wiggling it around a lot while painting it. look for leaking fluid, or pump brakes a few times, see if the piston needed to be pushed back out a little.
The possibilities are endless.
conspiracy90
Jun 7, 2023 01:01 PM
masongap
May 26, 2015 07:55 PM
rhvic
May 22, 2015 03:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
