Offset question
Old Apr 26, 2006
yellowgqthug817's Avatar
yellowgqthug817 is an unknown quantity at this point
Offset question
I just bought some Enkei ZR2 17X7 4-100 with a 40mm Offset...
I was just wondering if the offset is correct because on the sticky forum it said +45MM offset.. Will these measure fit good on my 2002 Honda civic
Old Apr 26, 2006
rjngo's Avatar
rjngo will become famous soon enoughrjngo will become famous soon enough
you can get from +37 to +44 offset...+45 is the stock offset
Old Apr 26, 2006
hdave's Avatar
hdave is an unknown quantity at this point
an offset of 43 would be ideal but that should be fine.
depending on your drop, id suggest some 205/45/17 tires
yep 45 offset is stock, but keep in mind that a stock rim is 6.5" wide and 195 tire
Old Apr 26, 2006
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
so....a lower offset...say for instance the +37 that was mentioned...will give you more room between the inside fender and rim?
Old Apr 26, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
The FAQ DOES NOT specify an offset number, it gives a range. See the "Standard answer" thread and read the FAQ again.
None of this really matters if you already bought the rims anyways.
junkyardguy
Sep 2, 2015 06:07 PM
greentoaster
Sep 1, 2015 12:18 AM
Strycker
Aug 18, 2015 02:25 PM
martinsmartin
Aug 15, 2015 07:34 PM
Misfit2613
Jul 30, 2015 09:49 AM
