need tire pressure tips
Originally Posted by JDMInspired
i want to start off with a good f/r tire pressure for auto-x
i am running 17x7 usng zeix512 205/40/17's whats a good pressure guys
Autocross Junky
How much camber are you running?
When I had "stock" camber with a set of 512's I had to run the fronts at around 45-47 to keep them from rolling over. the rears floated at around 35-37 depending on rotation needs of the track.
This is what Tirerack says:
"Tire pressures should be higher than used for the street, usually 45psi-Front/35psi-Rear for a front-wheel-drive car, or 40psi all around for a rear-wheel-drive car."
http://www.tirerack.com/features/solo2/handbook.htm
Put it high and work it down like they were saying. But thats a nice little handbook for other things.
Causemo
Jul 4, 2015 07:11 AM
