want to confirm wheel size will fit
Super Member
Rota Attack
17x7.5
48mm offset
56.1mm hub bore
4x100 bolt pattern
i am on 1.5 inch tein stech drop and will be using zeix 205/40/17's on them
There is no substitute
Ummm I don't like the 48 offset. That's probably gonna rub.
That bore is hubcentric.
Yeah, me too. The offset might be a little too high. It might not seem like much, but I'd go with the 45mm offset. They also make a 35mm, but that might be too small.
Regarding the hub size: 56.1mm hub bore is universal. Civics have pretty small hubs, but I don't have the specs. I'm sure you'll need hub rings. Some people will tell you they're not needed, but I like to be on the safe size. It's not worth having to put up with vibrations if the wheel's not centered.
Also, make sure they're good quality, and they fit both the wheel and hub nice and snug, you definitely don't want much (if any) play. Like boilermaker said, the bore is hubcentric.
205/40/17 are ideal, 215/45/17 would be of course better. 48 offset should not rub at only 1.5 drop and 205 width tires. When I researched on tires, 215/45's had much more variety of tires to choose from with a lil less cost.
cmart1209
May 29, 2015 04:52 AM
Touge
Ottawa
May 23, 2015 05:39 AM
Touge
Touge
May 20, 2015 10:53 PM
