Wheel weight MR7's
Old Mar 16, 2006
rockrosa's Avatar
Blacked Out Crew
rockrosa is an unknown quantity at this point
Wheel weight MR7's
If the stock steelies are around 40lbs with the tires and hubs. How much more would the Motegi MR7's (24lbs w/o tires) with radial tires wrapped on? Is it that much of a difference to effect performance? Will it wreck my manual transmission?
Old Mar 16, 2006
LiVe bAiT's Avatar
LiVe bAiT is an unknown quantity at this point
no its not gonna wreck it. i have those rims in 18s. dont know how much they way. but have np.
Old Mar 16, 2006
rockrosa's Avatar
Blacked Out Crew
Did you notice if it was a bit sluggish when you first accelerate?
Old Mar 16, 2006
gh0st's Avatar
TAQUITOS!!!!
weigh it and let us know. my 17's were heavy bastards.
Old Mar 16, 2006
burke420's Avatar
The World Is Yours!
i'd probably say aroound over 30lbs with tires
Old Mar 19, 2006
aki's Avatar
aki
aki is an unknown quantity at this point
Way over 30 lbs. Tires w/ air weigh about 20 lbs so it's about 44 lbs. MR7s are heavy as heck. U'll notice the car being a bit slower on its feet.
Old Mar 19, 2006
mugenman's Avatar
"mmmBAHHHH" - vtec y0
the motegi mr7's are one of the heaviest wheels out there i think. but damn they sure do look good
Old Mar 19, 2006
LiKEaFeRiO's Avatar
For the stickied FAQ...
Q: What is inertia and what does it do?
A: Inertia is the energy required to get your wheels moving. The larger the rim, the harder it will be to turn at first because the weight is concentrated farther from the center of rotation (the wheel hub). Bigger rims also tend to be heavier and the combination of increased weight and inertia is not helpful if you're trying to go fast. However, larger rims (to a point) with lower profile tires are beneficial for cornering, as there will be less roll under of the tire due to the smaller side wall.
24 lbs sounds like you are going for 17x7 wheels.
They are 24.5 lbs according to www.wheelweights.net
We can't tell you how much it will weigh with tires because all tires are different.
Go to www.tirerack.com and look at the specs of the tires you want.
Add the tire weight to 24.5 and you've got your answer.
Old Mar 19, 2006
Dticalman81's Avatar
Dticalman81 is an unknown quantity at this point
Yeahh.... How'd you know that? I have the same wheels and that's the first thing I noticed. I guess it just looks good for its looks.
Old Mar 19, 2006
pon55's Avatar
well i just got 16s, 20 lbs i think!
Old Mar 20, 2006
rockrosa's Avatar
Blacked Out Crew
I'd rather sacrifice a little speed and look good. Remember, without a turbo kit, we do drive CIVICS!
nirvanaguy
25
Oct 26, 2017 07:26 PM
twd000
Oct 4, 2015 12:52 PM
siliconvalley
Sep 15, 2015 09:48 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
rainman15
Sep 6, 2015 11:10 AM
