Good offset of 16x7 rims?
Old Jan 27, 2006
tamazoid's Avatar
tamazoid is an unknown quantity at this point
Hi!
I'm thinking of getting a set of Rota Slipstream in a 16x7 for Autocross... And my question is, what's a good offset for this size? Is +40 or +45 better? Thanks!
BTW, I did a search but couldn't find exactly what I'm looking for... Thanks!
Andrew
Old Jan 27, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Wider track (less offset) is better, but find a 15x7.
Old Jan 27, 2006
tamazoid's Avatar
So I guess the 40 would be better for the rims I wanted. Make it more flushed...
But I think 15 is too small I find. Too much flexing or tire roll...
Old Jan 27, 2006
Jap-Euro Fusion
Add more pressure.
Old Jan 27, 2006
Al Gore FTW's Avatar
jdmtytedoridori
Add more pressure.
^listen to this guy...
Old Jan 27, 2006
tamazoid's Avatar
Well if I add more pressure, there will be less grip...
Old Jan 27, 2006
Jap-Euro Fusion
Well then you need to do some serious alignment work. You have the ability to run lower pressures by getting the alignment to the point where the tire doesn't roll over on the sidewall. If you're alignment isn't right, then you're not gaining anything.
The use of a 205/50/16 tire over a 205/50/15 tire accomplishes nothing but make the car slower because of the increase in overall diameter. The sidewall is the same height, it flexes just as much. If you're thinking of using the 205/40/16 falkens I wouldn't. The load rating isn't high enough to support the weight of the car.
Old Jan 27, 2006
tamazoid's Avatar
205/50/15 is faster, but the overall diameter of the wheel is too small from origial specs...
And I was planning to run 215/45/16. It's still small, but not as small.
I think my camber is fine... I have -0.5 in the front and around -2.3 in the rear...
Old Jan 27, 2006
Jap-Euro Fusion
pffft. Thats completely *** backwards. No wonder you've got problems.
-2.3 in the front, -.5 or -1 in the back would be more like it.
205/50 is not too small, its what most of us run to race. Screw the odometer, you take the wheels off when you leave anyways.
Old Jan 27, 2006
tamazoid's Avatar
Ok either way, I'm still want to go with 16x7... Thanks for your help!
Old Jan 27, 2006
Jap-Euro Fusion
whatever....
Old Mar 24, 2006
trance4mer's Avatar
trance4mer is an unknown quantity at this point
where can i find a good set of 15x7 rims?
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
LikeWh0a
Nov 27, 2001 04:24 PM
